Classifieds => Wanted => Topic started by: croat1 on February 17, 2019, 01:15:50 AM
In desperate need of a NOS 88/89 right side case
88/89 foot peg mounting hardware
87-89 stock cylinder and head (NOS).
Thanks
What. Exactly do you need in terms of foot peg mount
hardware.?are you looking for nos or. Usable Hardware
Steve, I need the pins and springs. NOS would be great but nice used is ok also.
Ok joe I may have them I’ll check when I go to my garage..they’re not nos..
Actually 85 to 89 right side cases are the same The whole engine is the same. The only difference is 85 & 86 are short rod engines. 87 to 89 are long rod engines. There are slight differences in different year heads. as a matter of fact i have an extra cylinder and head
Mostly true. If you look at the very front of the engine where the mounting bolt goes through the cases there is a difference in appearance. If you mix and match cases you will notice the difference. The earlier cases had more of the bolt exposed than the later cases. Thanks Loren
(http://thumbs2.imagebam.com/18/c3/d2/78067b1144481794.jpg) (http://www.imagebam.com/image/78067b1144481794) (http://thumbs2.imagebam.com/f6/83/e4/98653f1144481834.jpg) (http://www.imagebam.com/image/98653f1144481834)
I think you have that swapped around Loren. Early cases had less of an opening. 88-9 had the bigger opening
I do have it swapped around. Thanks Gene lol
Keep in mind the color difference also. The right side case I’m looking for is for a buddy that is doing a complete NOS build.
@meathead, the cylinder and head that you mentioned...new?
I was really confused how my trike cases have the V style opening lol. I had also read elsewhere that the V style was late model. Thanks for clarifying Gene.
There's more subtle differences between all the years than most realize.
Absolutely
CROAT 1 No its not new, but i'm pretty sure it has a stock bore. You probably want a matched set of cases.
Honda didn't even sell them as sets
I stand corrected. Sorry for my ignorance.
No ignorance just letting people know
Joe sorry your thread got cluttered
Still looking
Thanks
One last bump....anyone have the parts?
Thanks
I probably have all the parts you need....I'll let you know what I have tomorrow...
