Workshop => Engine and Bottom End => Topic started by: The norm on July 20, 2019, 10:17:49 PM
Hey fellas, I just picked up my 391 from hybrid engineering and I had Pete install a pvl ignition. The wires for the pvl don't have a grommet and I obviously do not want to run without one. So help me out here. What is the hot setup for sealing the hole in the case? Thanks Loren
(http://thumbs2.imagebam.com/5b/6e/81/6b23881280405354.jpg) (http://www.imagebam.com/image/6b23881280405354)
I would think a normal grommet with some good old silicone would work
A .50 grommet not included? What the what? As Gene said. McMaster-Carr should have what you need.
As Gene stated...do you have any junk stators? Call and see if Ricky Stator (or the other aftermarket electrical places) will sell a grommet.
I have a junk stator just not sure if I can cut it off without destroying it. I will give it a shot because I can't wait to see what this engine will do!
