Workshop => Engine and Bottom End => Topic started by: atvmxr on June 04, 2020, 10:55:59 AM
Title: shorty spark plug?
Post by: atvmxr on June 04, 2020, 10:55:59 AM
Is there a shorter version of the typical B8xxxx used in most 2 strokes?  I need like a 1/2" extra clearance on a hybrid.
I betcha Mr. Pritchard would have known the answer, RIP.
Title: Re: shorty spark plug?
Post by: Jerry Hall on June 04, 2020, 02:10:10 PM
NGK makes a special spark plug that has a rare earth ground electrode that has a short top on it.  We had to use them in the RS125, the 2 cylinder RS250 Hondas and some of the other highly developed 500cc-4 cylinder road racing engines that had detonation problems and or had detonation sensors under the spark plug. It also requires a special spark plug cap for these short top spark plugs.  The spark plug we used was a NGK R7282 and has a heat range around "10 to 11" on the NGK scale.  I have not bought any of these spark plugs in 15 to 20 years, but I would guess that the price today is probably around $60.00 to $80.00 each with the spark plug cap costing around $50.00.
I do not know if NGK makes any other heat ranges  in the 7 to 9 range with the short tops.  Our single cylinder 250s to 500cc recreational engines will foul a spark plug like the R7282 because they do not produce the high combustion temperatures that these 55 to 60HP per cylinder (125cc) road racing engines produce.
Post by: atvmxr on June 04, 2020, 03:03:36 PM
thank you Jerry!  Its actually for my sons RM85 shifter quad Im building, which stock plug is a 10 heat range.  At $40 a pop though (summit racing), Id probably just be better off having a custom aluminum fuel tank made for it.
