General => Pics and Vids => Topic started by: croat1 on February 28, 2021, 08:49:14 AM
Title: Tips and tricks
Post by: croat1 on February 28, 2021, 08:49:14 AM
Clutch actuator arm modification.  Not the best pic but easy enough to understand what has been done.
Title: Re: Tips and tricks
Post by: croat1 on March 04, 2021, 12:21:08 PM
Additional stock cylinder sleeve protection during storage or shipping.  Take the core from a used up roll of packing/shipping/duct tape.  I remember seeing this tip many years ago.
Post by: Hawaiiysr on March 04, 2021, 02:19:49 PM
i use a scrap piece of pvc
Post by: croat1 on January 28, 2022, 08:01:17 PM
Who remembers doing a stator cover vent.  I never did it.
Post by: croat1 on January 28, 2022, 08:03:50 PM
Seat foam repair tip from the late Michael S.
Post by: Jerry Hall on February 04, 2022, 06:25:17 PM
I never put a vent in the magneto cover, but I have put drain plugs in a lot of covers.   I would put the  drain plug in the lowest part of the cover and removed the plug after the bike has been ridden in water or after it is washed.  I would leave the drain plug out and install it just before the next ride.  It allows any moisture that may have leaked in around the wire sheath or wire grommet to evaporate.
I have worked on many 250Rs that had a good mag cover gasket and wire grommet that had a completely destroyed mag side crank seal.  The bike ran fine and did not have any symptoms of an air leak.  For this reason would not put a vent on the cover that was open to the atmosphere when the engine is running.
Post by: croat1 on February 06, 2022, 07:11:26 PM
Makes sense. Thanks Jerry for your input.  Greatly appreciated.
Post by: croat1 on May 25, 2022, 10:48:16 PM
Seen this searching.  Too good not to share.
Post by: croat1 on August 03, 2022, 07:14:51 PM
Might save the day…faulty CDI fix?
Post by: croat1 on August 26, 2022, 10:46:38 AM
Front Brake line tip.
Post by: croat1 on September 11, 2022, 10:11:08 AM
Here’s a good link for softening rubber parts that have hardened.
https://v4musclebike.com/forums/showthread.php?t=13477
Post by: 2ndmoto on September 11, 2022, 01:55:46 PM
That's very useful. Thank you
Post by: Langbolt on December 08, 2022, 09:43:07 AM
If you ever need to FIX a Bent or crushed Foot Peg.....Here's a simple tip!
Take a M8 fully threaded bolt......insert it into the hole in the middle of the peg....or where the bend is.
Install a nut....screw it through the nut.....and then install a 2nd nut......thread it through so the threads come out the other side of the peg.
Now using a wrench.....tighten the first nut against the peg and then the 2nd nut.....using it like a spreader to push out the dent!
VOILA!
LOOKS LIKE NEW!
 ;D
Post by: Langbolt on December 08, 2022, 11:53:56 AM
For anyone that wants to replace their Rusty & corroded Rear Master Cylinder rod - the Suzuki (Part#69670-00A00) fit's like a charm!
Post by: Langbolt on December 08, 2022, 12:01:46 PM
If you lose the discontinued collar that goes with the bolt that holds your front OEM fender in place.....no worries...just replace it with this HONDA Part#90104-MEN-A30.....It has the shoulder built into it!
:D
Post by: broken1 on December 08, 2022, 02:20:58 PM
I recognize that rear MC :) It's been working 4 years now with the Suzuki push-rod & had no issues.
Post by: atvmxr on December 09, 2022, 11:21:34 AM
:D
thank you!  i had a post somewhere where I was talking about how I thought the R came with an encapsulated collar, but no one knew what I was talking about.  guess the previous owner swapped them out
Post by: Langbolt on December 09, 2022, 05:12:12 PM
If you're looking for the rubber grommets that go on the frame pegs to support the front of the Air Box (Honda Part#  19032-HB9-000 - DISCONTINUED) Item# 28 on the Air Cleaner fiche - Have no fear! YAMAHA has a grommet that works perfectly!
YAMAHA Part# 90480-12053-00
 ;D
Post by: croat1 on December 12, 2022, 08:31:12 AM
John, nice find on the air box grommet and shouldered fender bolt.
Post by: croat1 on April 08, 2023, 08:17:27 AM
If your exhaust flange has no spring mounts you can use some #428 chain side plates.  Drill and bend as needed.
Post by: croat1 on January 31, 2024, 05:32:35 PM
Air box filter sheet
Post by: croat1 on February 01, 2024, 09:00:43 AM
Cable operated choke
Post by: croat1 on September 26, 2024, 10:04:26 AM
Oem 8 plate clutch
Post by: croat1 on May 08, 2025, 02:46:35 PM
Another faulty CDI fix is to heat it in the oven.
http://pilotodyssey.com/PO/viewtopic.php?f=24&t=18604
