Workshop => Suspension and Chassis => Topic started by: atvmxr on January 07, 2022, 09:27:13 AM
Title: Mounting shock reservoirs?
Post by: atvmxr on January 07, 2022, 09:27:13 AM
You guys got any bright ideas how/where these TCS rezzies are supposed to mount?
There isn’t a 90elbow connection exiting the shock so mounting in the usual spot has the hose making a couple tight bends.   Gonna use the schmidty racing rubber mounts.
Hose is too short to mount behind radiator
Title: Re: Mounting shock reservoirs?
Post by: The norm on January 07, 2022, 09:39:59 AM
I ran into the same issue when trying to mount my fronts. I went ahead and mounted them similar to your first picture. My axis shocks had 90° elbows and I was able to get a little better fit up by rotating the elbows.
https://www.imagebam.com/view/ME669SJ
Post by: croat1 on February 08, 2022, 09:03:32 PM
Did you get these mounted?
Post by: atvmxr on February 11, 2022, 09:39:27 AM
yep, like in the first pic. its goofy, but seemed to be the only option
