Workshop => The Mad Scientist => Topic started by: 69HemiGTX on May 28, 2022, 02:11:28 PM
Title: Transmission ratios for 250R-based hybrid project
Post by: 69HemiGTX on May 28, 2022, 02:11:28 PM
Howdy again, y'all! I haven't posted here in forever, but I figured I could pick the brains of some of y'all for advice. My question concerns using a dirt bike engine in a 250R-based ATV. Specifically, what transmission ratios would work best given the following combinations in the attached table? What would be a good starting point for final drive ratios? The primary riding will be in the dunes and trails, with some trips into the woods every once in a while. I'm not interested in drag racing at all. Any reply would be greatly appreciated.
Title: Re: Transmission ratios for 250R-based hybrid project
Post by: croat1 on May 30, 2022, 07:19:38 AM
What engines are they?  By chance is option 1 a YZ400/426?
Post by: 69HemiGTX on May 30, 2022, 08:25:29 AM
KTM SX, XC, and XC-w in that order.  All 250-300cc two-strokes.
Post by: croat1 on May 30, 2022, 05:57:04 PM
I was curious as what guys were using for the KTM 2 stoke conversions.  After about 30 minutes online I found this.  I did reach out to a old R guy that’s into Hybrids big time now.  I’ll post what he responds with.
Post by: 69HemiGTX on May 30, 2022, 09:21:28 PM
That's kind of what I was thinking because first and second are lower geared, but some riders complain about the gap between second and third.  Compared to the KTM, the 250R has lower ratios for each gear and had a 13:38/39 final drive depending on model year.  I wonder if something like a 13 paired with a 40 or 41 would drop the KTM's ratios closer to the 250R.
Post by: Jerry Hall on May 31, 2022, 12:57:39 AM
How do the primary ratio (crank to clutch} ratio compare to the Honda 250 ratios?
 Remember the overall ratio is the:
                                                         1 / [(primary ratio) x (transmission ratio) x (the sprocket ratio)] x (the circumference of the tire) = (the distance traveled per engine rotation)
Post by: croat1 on June 18, 2022, 02:33:32 PM
He said to use the XC or XC-w
