Workshop => Engine and Bottom End => Topic started by: All250R on May 31, 2022, 11:26:19 AM
Title: Trouble disassembling/separating PT 89 Race pipe
Post by: All250R on May 31, 2022, 11:26:19 AM
Guys,
I think years ago I put some RTV in the joint that separates the header from the main body. I'm trying to get the pipe off the bike, but I cannot get the two sides separated. Any tips? I'm short of taking a sawzall to it...
Jason
Title: Re: Trouble disassembling/separating PT 89 Race pipe
Post by: croat1 on May 31, 2022, 12:21:24 PM
Hi Jason, try some heat and a strap wrench.
Post by: The norm on May 31, 2022, 02:09:03 PM
Kroil penetrating oil/solvent works great on RTV. It also helps with rusted/crusted metal on metal connections. Spray some on and let it sit for a while then go after it with the strap wrench like Joe suggested. Heat will also work to break down the RTV.
Post by: broken1 on May 31, 2022, 08:52:48 PM
Whatever you do, please don't take a sawzall to it. You'll eventually get it off but you should also be proud of the fact you had that sucker sealed up good. Mine usually leak
Post by: All250R on June 02, 2022, 02:57:46 PM
The strap wrench did it before I had to apply any heat. Thanks Joe. I applied some pb blaster, though not sure how far I got it into the joint.
Let me know if anyone is interested in trading for a not-rusted trx9 pipe.
