Workshop => Suspension and Chassis => Topic started by: Vegas_Trx250r on July 26, 2022, 07:51:48 AM
I bought a new rear axle, swing arm, and bearing case. Do I grease the axle before I install it into the bearing case?
New to the ground up build.
I always do. Don’t forget to grease the rotor hub splines and nut threads.
Yes grease the axle and the splines. It makes life easier when doing a future teardown and will also make the splines last a little longer.
So, I headed the axle up. Do I need to compress the axle into the bearing carrier?
The axle bearings are a slip fit so the axle should slide right into the carrier.
Kind of what he said above, I actually just installed the same exact axle in all their same parts and nothing extra was needed. Just greased and slid right in.
@Vegas_Trx250r - Watch this :)
https://youtu.be/RgZQjIxifls
