Author Topic: Honda TRX250R Exhaust Systems  (Read 52452 times)
Offline ledperformance
« on: August 23, 2013, 05:46:20 PM »
Chrome LED TRX250R big bore pipe and silencer.
LED TRX250R exhaust.
LED TRX250R exhaust chromed.
LED TRX250R silencer.
Click here to order.
« Last Edit: August 26, 2013, 03:46:43 PM by ledperformance »
Offline ryanowarrior
« Reply #1 on: August 23, 2013, 10:51:11 PM »
When can we order the 250r pipe and silencer
Laeger Crf
Laeger R
Walsh R
Walsh Crf (in the works)
Offline fx4pitrone
« Reply #2 on: August 23, 2013, 10:55:34 PM »
Sweet pipes!  Are prices listed anywhere?
« Reply #3 on: August 24, 2013, 06:42:02 PM »
You can order them right now! Click here to see our store page.
« Reply #4 on: August 24, 2013, 09:39:43 PM »
Quote from: ledperformance;9833
these listed above are they suitable for a ESR 310?
Laeger Crf
Laeger R
Walsh R
Offline Bigred
« Reply #5 on: August 26, 2013, 12:29:32 AM »
Any specials on over stocked pipes at all
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
« Reply #6 on: August 26, 2013, 12:46:38 PM »
Quote from: ryanowarrior;9850
The 250 / 300 pipe will work on any 295- 310 kit. The ESR 310 is a 72mm bore which makes it a 295 cc kit.
« Reply #7 on: August 26, 2013, 12:48:33 PM »
Quote from: Bigred;9978
We don't have any overstocked pipes.
Offline Bigred
« Reply #8 on: August 26, 2013, 12:54:21 PM »
O ok thanks ill have to wait a bit longer then
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
« Reply #9 on: August 26, 2013, 12:56:56 PM »
Quote from: ledperformance;10025
awesome..thank you that's what I'll be ordering then!
Laeger Crf
Laeger R
Walsh R
Offline Bigred
« Reply #10 on: August 26, 2013, 12:58:23 PM »
Hows the bare pipe hold up? Its bare steel obviously but is the metal treated in anyway to help prevent rust
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #11 on: August 26, 2013, 01:00:03 PM »
O ya also dose it clear oem front full fenders or do u have to trim the fender
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
« Reply #12 on: August 26, 2013, 01:07:12 PM »
It will clear the fenders. The non-chromed pipes need to be sprayed with WD-40 to keep them from rusting. Limeaway and a Scotch bite pad is good for cleaning them.
« Reply #13 on: August 26, 2013, 03:47:14 PM »
how do you feel about coatings on your pipes?  for example: jet-hot or a hi-temp clear powder.
« Reply #14 on: August 26, 2013, 03:51:36 PM »
Quote from: jcs003;10047
Thats fine.
