Author Topic: Crank Seals  (Read 4985 times)
Offline spintly
Crank Seals
« on: August 26, 2013, 07:25:56 AM »
Hello All.  What brand of crank seals are you using?  I mostly run OEM Honda, but is there a company making better ones?  Thanks
Crank Seals
« Reply #1 on: August 26, 2013, 08:13:10 AM »
I do not believe anyone makes better than OEM but you might find some equal, kind of hit and miss with the aftermarket stuff
Crank Seals
« Reply #2 on: August 26, 2013, 08:37:41 AM »
Strictly OEM
Crank Seals
« Reply #3 on: August 26, 2013, 10:12:54 AM »
OEM crank seals only. There are a few japan main bearings that would be ok but do not mess with the crank seals...
Crank seals and main bearings must be held to a very high std and if that means more money then the options so be it. TOP quality is beyond highly recomended here.
Crank Seals
« Reply #4 on: August 26, 2013, 10:23:43 AM »
I have used OEM and Hot Rods crank seals, both with great success and zero issues.
Crank Seals
« Reply #5 on: August 26, 2013, 11:29:31 AM »
Also...maybe if we keep the purchase volume of OEM seals high then they won't discontinue them....who knows
Offline spintly
Crank Seals
« Reply #6 on: August 26, 2013, 03:12:10 PM »
Thanks Guys.  Just purchased another OEM seal.  That is all I have run in the past, just didn't know if there was something better.  I sank the seal too far into the case and it didn't seal on the spacer by evidence of my pressure test.  I could actually feel the air flowing through when I had held my hand over it.  This is the first time I ever rebuilt my engine and thank goodness I made the pressure tester and tested it.  Glad to know I had an issue prior to firing and running my fresh engine.  I know not to sink it too far in now, but does the seal sit flush with the case?  I was just gonna put it in with a 1/8 before being flush with the case, then pressure test it and see if I need to sink it in further.  I know I don't want to go past flush with the case.
