Author Topic: What to do with motor  (Read 9122 times)
Offline Victork
« on: July 05, 2013, 09:10:48 AM »
Right now I have a 350 pro x with a long rod. I'm wondering how I'd do with a good porting with 4 mill crank, custom pipe and lectron. If that would get me  going good I might wait on a cub.
Offline Polonda
« Reply #1 on: July 05, 2013, 09:14:29 AM »
Has the cylinder already been ported?
Offline Victork
« Reply #2 on: July 05, 2013, 09:16:55 AM »
CT standard dune port but I want more top end...
Offline Polonda
« Reply #3 on: July 05, 2013, 09:32:34 AM »
Not sure what CT sets the port timings too on a dune port, but if I had to guess you will end up with at least a drag port just by putting in the 4 mil crank.  You'll want to see what your timings are and then go from there to determine if you can go with the 4 mil or not.  You may have to stick with the stock stroke and then have the cylinder ported again for more top end.
« Reply #4 on: July 05, 2013, 09:38:06 AM »
ask troybilt about his saber cylinder.  i believe its for sale.  that will give you some top end.
Offline motofool250r
« Reply #5 on: July 05, 2013, 11:57:46 AM »
adding a +4mm crank and a full port job from someone who i would say is a master carver could net you 5-10whp if your building a duner bike. if your wanting to add a lectron and a drag pipe with alky you could gain more, probably upto 15whp depending on who builds and setups your stuff.
Hybrid Stable
443cc LSR/Roll/Stellar Duner
363cc Backup Duner
In progress JP no-link Duner
Next bike now loading.....
Offline Victork
« Reply #6 on: July 05, 2013, 12:21:54 PM »
I use 110 or 114 sonoco. I don't want to tear down until October so I can ride. I was thinking about keeping my set up as its very good in the woods and getting a ATC and doing a puma. I need something top end for play and some hill climbing.
« Reply #7 on: July 05, 2013, 12:27:07 PM »
+4mm crank would be the cheaper route with any cylinder you choose, as the +6mm cranks go up in price very fast.
a good running 431 puma will put a smile one anyones face that doesn't have a saber already =P
Hybrid Stable
363cc Backup Duner
Offline Victork
« Reply #8 on: July 05, 2013, 04:59:00 PM »
I don't know how ct calls this a mid/top port because it feels like a bottom/mid motor. Must be the lrd pipe. I'd I can make a big difference with what I have now I will.
Offline Duner
« Reply #9 on: July 05, 2013, 05:06:15 PM »
CT porting is decent at best. 350 is a great cylinder to run around on. Had one for a while (CT) in a TRX I had. Was a blast to ride. Its a play motor, MX, Dunes, trails, etc...
Have a decent Honda builder work over the cylinder for porting and get yourself CR ign...this will wake it up.
Along 4 the Ride
« Reply #10 on: July 05, 2013, 05:30:40 PM »
Victor whats the goal here ? just more power?
Hybrid Stable
363cc Backup Duner
Offline Victork
« Reply #11 on: July 05, 2013, 07:05:00 PM »
Yes, I'm wondering how well I'd do with a new top end, striker crank, custom pipe and lectron
« Reply #12 on: July 05, 2013, 07:08:13 PM »
k so is this a duner, or a drag bike? or? do you do alot of part throttle riding or only wide open or idling?
Hybrid Stable
363cc Backup Duner
Offline Victork
« Reply #13 on: July 05, 2013, 07:10:09 PM »
I do it all and seem to always be 3/4 to wide open. I need to do some trails but focus is on play drag, hill climb, dirt roads.
« Reply #14 on: July 05, 2013, 07:14:53 PM »
then you will probably like the lectron.
Hybrid Stable
363cc Backup Duner
