Author Topic: 87 full part out. Located in erie pa  (Read 8798 times)
Offline Bigred
« on: September 02, 2013, 08:16:36 PM »
First off ill stand by my descriptions on the parts I'm posting. I have put about 4 hours run Time on this quad to make sure everything was up to par. I will give a 3 day full refund on parts from the arrival time. I would like it if you buy a part just to let me know you recieved the part and are happy with the deal. It needs to be a legit reason. Also if u still want the part and there is a problem I'm more than willing to work with you on how much cash if any is to be returned to make it right. Now to the parts
Stock red tank dose have spider webbing no leaks probly 5 outta 10 on the top apperance comes with mounting hardware, bolts, petcock, and gas cap 60 shipped
Rear tires and rims had someone interested but can't remember who. Itp rims never been ran nicks on outer lip buddie put tires on with a screwdriver one tire holds air for 3 days then goes low 150 plus shipping
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline Bigred
« Reply #1 on: September 02, 2013, 08:25:17 PM »
Front tires and rims 125 plus shipping
Dominator 2 rear axle with hubs and sprocket hub 250 plus shipping
87 rear swing arm comes with swim arm bolt bearings are good no play 135 shipped
Stock front a arms spindles and rotors all good bushings and ball joints plus steering rods one has a little play but not much 200 plus shipping
Stock air box with drilled lid 45 shipped
« Last Edit: September 02, 2013, 10:39:14 PM by Bigred »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #2 on: September 02, 2013, 08:49:04 PM »
Dual row carrier bearings seam tight and good 100 shipped if there all good sorry no pic
Lock nut 50 shipped
Stock rad 35 shipped
Stock thumb throttle pretty sure it's from a r 35 shipped no cable
Front and rear brakes levers and lines. Needs rear brake line 200 plus shipping
Oem over flow bottle 35 shipped
Motor 850 plus the ride what I was told its a 87 bottom, had Wisconsin 265 kit put in it not many hours on it also ported for mid not sure on porter. Comes with stock stator wiring harness cdi kicker shifter all motor mount bolts. I put 4 hours on this motor it pulls good and runs great pulled the wheels 1-4th no leaks noticed. Now I will pull the head and measure for serious buyers also will take pics of intake and exhaust. I will give you a weeks time apon arrival to make sure it's up to par with my description and ur happy with ur purchase. I will give a full refund and split the shipping back to me or if u still want it and there is a issue we can solve it and keep both parties happy.
Sorry only pic I have of motor no noticed case damage was painted at one time will be removed tomorrow and will post more pics
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #3 on: September 02, 2013, 08:57:32 PM »
Steering stem is stock straight and black 50 shipped will get pics when removed
Front fenders maier make a offer no cracks I'd give um 6 to 7 outta 10
Nerf bars not bent make offer have new mounts for the peg area
Carb to air box 40 shipped was on a 38mm carb
If there is something I didn't post yet let me know ill get pics and a price
Parts that are spoken for and sale pending are the following
Carb
Seat rear plastics
Seat
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #4 on: September 02, 2013, 09:09:49 PM »
Parts I'm looking for will take on trade probably a long shot lol
89 clutch update kit
A nice reed cage setup
+1 a arms
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #5 on: September 02, 2013, 11:37:03 PM »
Nerfs pending sale for tretimit16
« Last Edit: September 02, 2013, 11:49:43 PM by Bigred »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #6 on: September 03, 2013, 11:56:47 AM »
Also have a 38mm air striker carb 150 shipped pics are on my phone I cand send them
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #7 on: September 03, 2013, 09:36:51 PM »
Bumping it
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #8 on: September 04, 2013, 08:17:14 AM »
I can seperate stuff. I just figured I posted them for best bang for the buck
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #9 on: September 04, 2013, 12:56:36 PM »
Error
« Last Edit: September 04, 2013, 01:14:51 PM by Bigred »
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #10 on: September 06, 2013, 10:17:16 AM »
Other gas tank cover.  sale pending
Carb to airbox boot. Sold
one set of wheel spacers. sold
headstay gone to settle a delay on my half.
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #11 on: September 07, 2013, 11:09:01 AM »
Bump
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #12 on: September 08, 2013, 08:45:51 PM »
Front plastics sold
carb and cable is. sale pending
front brake master. Sale pending
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #13 on: September 11, 2013, 07:23:11 AM »
Bump
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
« Reply #14 on: September 21, 2013, 05:51:42 AM »
Bump
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
