Author Topic: Klotz oil prefrance  (Read 9463 times)
Offline pantera1975
Klotz oil prefrance
« on: September 03, 2013, 08:55:21 PM »
I used Klotz R 50 on my motors when old switched to Maxima 927 when I had both motors redone and my wife complained it stunk to bad so I went Koltz super technicna plate with castor. I really cant stand the smell either. Would I change my engine life using just R50 over the stuff with Castor?
Klotz oil prefrance
« Reply #1 on: September 03, 2013, 09:54:24 PM »
I run R50 or Benol in everything I own.  I have good results with all of their products and it is the only thing I will ever run.  Everyone has their own personal preferences.
Klotz oil prefrance
« Reply #2 on: September 03, 2013, 10:59:27 PM »
Probably not, castor is a little better, but only at the point of normal mineral oil breaking down.
 Before then I dont think there is any advantage and the bearings probably dont care either way, more of a slightly better piston scuffing protection with castor IMO.
Offline jamieg45
Klotz oil prefrance
« Reply #3 on: September 03, 2013, 11:19:45 PM »
I started with klotz and switched to amsoil, only because when I pulled one of my banshee motors apart I didn't like what I saw, and then the same with one of my R motors too. It was like there was honey in the cases and the dome and piston was built up with too much carbon. I have pulled my R motors apart after amsoil and they look great, I was sold at that point. Been running it since then and I wont change either, But I miss the smell of my benol.
01 Lsr 250r
00 Walsh 250r
Klotz oil prefrance
« Reply #4 on: September 03, 2013, 11:20:08 PM »
who cares what youl ol lady says. put some castor in that sum *****
Klotz oil prefrance
« Reply #5 on: September 03, 2013, 11:25:53 PM »
never seen a fast bike using amsoil. just sayin
Offline PORTED R
Klotz oil prefrance
« Reply #6 on: September 03, 2013, 11:56:53 PM »
I run klotz super tech,its a good oil ,I've noticed carbon build up on piston dome and head
But it wasn't caked on or in crumbles ,cylinder sleeve looked good and crank bearing were well lubed
McCoy ProX 350 5mil Duner
Klotz oil prefrance
« Reply #7 on: September 04, 2013, 12:11:51 AM »
That's weird Jamie....were you running the same ratio with both oils?  Sounds like it was lean.  We have worked on alot of stuff over the last 10-15 yrs. and have never had any issues with any Klotz oil.  Was always very impressed when I seen how well everything in the motors looked.
Klotz oil prefrance
« Reply #8 on: September 04, 2013, 12:13:56 AM »
These ^^^^^ are both fricken hilarious!
Offline jamieg45
Klotz oil prefrance
« Reply #9 on: September 04, 2013, 12:52:45 AM »
So now he's sayin my bike is slow be wise I run amsoil, and the klotz I ran 32-1 and now I run 40-1 and I really like it much better.
01 Lsr 250r
00 Walsh 250r
Offline mennis1971
Klotz oil prefrance
« Reply #10 on: September 04, 2013, 06:21:19 AM »
I think it's important to remember to be jetted for the oil AND mix ratio you're running. I used to run Klotz stuff for years, but always jetted rich(just a little). IMO the Benol was the worst for carbon buildup, but 927 will do it too but not as bad. R-50 isn't bad oil either, had no problems with it(doesn't it have like 10% Benol in it?). I'm running 927 now(and have been for quite awhile) with no problems.  I've never tried any Amsoil so no comment LMAO. I can't believe that it's any better or worse than anything else. See first sentence!!!!!
Klotz oil prefrance
« Reply #11 on: September 04, 2013, 06:41:38 AM »
Quote from: red88r;10978
^^ Agreed ^^ Love the Benol!! :encouragement:
Klotz oil prefrance
« Reply #12 on: September 04, 2013, 08:57:12 AM »
Supertechniplate here. Run 32:1 and bike is jetted correctly. I see NO carbon build up or any residue I am worried about.
Klotz oil prefrance
« Reply #13 on: September 09, 2013, 09:55:33 PM »
supposedly the benol with mix in alcohol up to 5:1. anybody tried something like that ?   i always like a good experiment. maybe ill give it a go  :redbull:
Klotz oil prefrance
« Reply #14 on: September 09, 2013, 10:00:15 PM »
16-1 is the highest ratio typical motors will still perform good with. 20-1 is best IMO.
The more oil you add the lower the octane of the fuel mixture.
