Author Topic: Any experience with these radiators? Input thx  (Read 5823 times)
Offline Maxxh2o
« on: September 05, 2013, 04:39:51 PM »
http://www.ebay.com/itm/Honda-TRX250-TRX250R-Aluminum-Radiator-86-87-1986-1987-/251290750924?pt=Motorcycles_Parts_Accessories&hash=item3a82188fcc&vxp=mtr
Any input on these radiators?  Probably get what you pay for I'm sure but thought I'd ask in comparison over stock
« Reply #1 on: September 05, 2013, 04:58:54 PM »
Ive used one,it will require a little bit of modding but overall they seem decent. I would buy another . I will try to post some more pics later
http://trx250r.org/showthread.php?1059-Radiator-question&highlight=Ebay+radiator
« Reply #2 on: September 05, 2013, 05:18:54 PM »
Last 1 I ordered I sent it back. China or whoever makes this stuff sucks. Says it ships from here. Did not say it was made here.
Offline Maxxh2o
« Reply #3 on: September 05, 2013, 05:29:34 PM »
Why did you send it back?  The lower outlet bend issue?
Offline Maxxh2o
« Reply #4 on: September 05, 2013, 05:30:52 PM »
If someone has a good deal on a PWR I'm interested....  By the time you pay fab time your probably out the same money
« Reply #5 on: September 05, 2013, 06:38:55 PM »
Quote from: Maxxh2o;11135
The outlet and breather were smashed.
Offline Mony25
« Reply #6 on: September 05, 2013, 09:27:54 PM »
Been running one for 2 years of mx with no issues. You can def. tell the quality isn't that of some others but I wouldnt be afraid to buy another.
01 lobo mx chassis axis shocks c-Leigh ported pro-x 310 (going bigger in future) 38 a/s esr trx 5 pipe hipers an holeshots cr 250 ign flex bars precision stabilizer
86 atc 250r all stock except pipe
Bunch of other 4 stroke atc\'s
Offline Wes350x
« Reply #7 on: September 05, 2013, 09:30:53 PM »
I used one and never had issues as well
1988 250R
Offline corvetteZ06
« Reply #8 on: September 05, 2013, 09:32:17 PM »
I'm running a ASI radiator (also an eBay special) for several years with no issues. Would order another for sure.
Offline The Phantom
« Reply #9 on: September 05, 2013, 11:14:03 PM »
I just bought the GPI radiator and I paid 30 dollars to have the outlet changed.  When my fab guy cut it off he said the hole in the radiator was only open about 25% of the size of the outlet.  Said it looked like someone used a punch to put a hole in it.  He opened it up for me.  mounts for the louvers on the front didnt match up real well.  Had to cut the un-necessary mount in the middle on the top because it hit my LSR steering stem.  Its def. not just bolt in and go.  You get what you pay for here.
« Reply #10 on: September 06, 2013, 08:37:05 AM »
Similar experience to others. I had to remove upper tab and louver mounts are a little off. The outlet clears the laeger chassis. I have not tried it on the '88 frame. I did explore the opening issue Phantom had and didn't notice any major restrictions.
