Author Topic: Dose any one have a pic off the bottom of a bolt on 330 sleave  (Read 2726 times)
Offline Outlaw525
« on: September 09, 2013, 11:17:39 PM »
1987 trx 250r esr310 kit
2007 525 outlaw irs
« Reply #1 on: September 10, 2013, 10:36:55 AM »
I dont have a pic, but can tell you theres only about 4.5mm of the sleeve sticking out of the bottom of the cylinder casting, so all you need is the 4.5mm spacer plate & two base gaskets to bolt it directly onto the 250R bottom end.
If your thinking of bolting it up flush onto the bottom end with no spacer plate, you'll need to machine the opening in the cases 3.350 wide & to at least 5mm deep down in that area to clear what little bit of the sleeve is sticking out of the cylinder casting.
You thinking short rod crank maybe ??.
« Reply #2 on: September 10, 2013, 11:52:49 AM »
well my memory must be getting bad but here is a picture of a 330 bolt on, it has major damage on the intake side but the exhaust looks just like yours
I swear the one I seen had a longer skirt here the link to the guys posts http://www.atvriders.com/vbb/showthread.php?501248-Little-Carnage-from-this-weekend
Offline Outlaw525
« Reply #3 on: September 10, 2013, 11:57:02 AM »
Thanks that make me feal better. Just need a piston and away I go.
2007 525 outlaw irs
