Author Topic: hot rods crank?  (Read 11162 times)
hot rods crank?
« Reply #15 on: July 07, 2013, 06:35:46 PM »
I have the crank puller and luv it BUT how do you know that you are not pulling the 2 crank halves out farther than they should be, believe it or not the crank pin can flex allowing the the crank halves to be slightly pulled father apart than it should be.
Rebuilt cranks can be a .010 or more narrower or wider, when pressing crank halves together the pin will jump a few thousands or more at a time while being pressed together, not just a easy press fit where you can sneak up on a exact number.
That is the whole reason I run a semi-slip fit on 1 bearing so the crank can find it natural center no matter how wide or narrow the crank is.
hot rods crank?
« Reply #16 on: July 07, 2013, 06:37:48 PM »
Offline Sky
hot rods crank?
« Reply #17 on: July 08, 2013, 11:26:15 PM »
Quote from: rsss396;1566
GREAT stuff Sir!
Offline mrmoto
hot rods crank?
« Reply #18 on: July 09, 2013, 01:57:26 AM »
This is brilliant! This is why I can sit here for hours reading threads until my neck is sore. I really dig finding this stuff out. I may never personally apply some/most of it be it still helps
Offline ayomainstreet101
hot rods crank?
« Reply #19 on: July 12, 2013, 03:23:15 AM »
Quote from: udontknowme;1223
talk with BDT about slip fits. i hear they got a new cnc mill
I want that cnc lol
Starting to love my 250r more and more!!
