Author Topic: LED 350 Sphynx XC Build  (Read 63667 times)
« Reply #60 on: March 21, 2014, 12:17:54 AM »
Boing!!!
« Reply #61 on: March 21, 2014, 09:07:16 AM »
Quote from: Hawaiiysr;29485
Hand cone pipes are beautiful. Cant wait to get me some LED love. I seriously will not reply to any more of your post if you plate that pipe. :black_eyed:
It is beautiful but it already has some very very minor surface rust and I haven't even used it yet! Some WD-40 will take care of it.
Killer_250R's pipe is chromed and it look sick. I'll see how long I can stand cleaning and oiling it
Offline fast350r
« Reply #62 on: March 21, 2014, 10:39:42 AM »
super nice motor and pipe man,, cant wait to see more
Shearer 431 puma
« Reply #63 on: April 07, 2014, 10:56:22 AM »
Got some good work done this weekend. The motor went in without a hitch, and got the LED 350G pipe all mounted up. Initially it was a pain to mount but once I got it adjusted it fits perfectly and is mounted very solid. Unfortunately the bolt hole on the Laeger headstay doesn't line up with the Sphynx head, but i'll need it for my steering stabilizer
I'm able to get about 3.5in of adjustment out of the pipe but i'll need some longer bolts if I want to go that far. I'm not sure how much of a difference the adjustments will make power wise, but it really helped with fitment of the pipe. It's tough fitting that bigger header through a Laeger narrow frame.
Offline silverlake250r
« Reply #64 on: April 07, 2014, 11:16:56 AM »
Looks awesome!
2002 Roll Design Lobo MX
Offline DnB_Racing
« Reply #65 on: April 07, 2014, 01:04:10 PM »
Quote from: Tbone07;31065
you might want to check the rest of the mounts..my 363 sphynx lined up to my protrax headstay.. I don't have a no link but I do have a narrow with the head stay with stabilizer mount...it took a few tries to get all the mounts perfect, but I got them all after playing around with it..
it was off like yours at first then I loosened everything and started over,a couple of times before they all fit
« Reply #66 on: April 07, 2014, 04:16:55 PM »
Quote from: DnB_Racing;31077
Ok thanks i'll have to fool with it some more. It's not off by much.
on a side note......where's the build thread for your quad? Lol
Offline DnB_Racing
« Reply #67 on: April 07, 2014, 06:51:45 PM »
Quote from: Tbone07;31096
I caught too much crap for using xxx so I decided to keep it too my self..when im done ill show some pics
Offline bnau267
« Reply #68 on: April 12, 2014, 09:40:59 PM »
Can't wait to see more...my LED package is due next week!
« Reply #69 on: April 14, 2014, 09:04:19 AM »
Little progress here....spent most of the weekend building an XC track, wait till you guys see that.
Got all my parts in from UPP. They look very high quality and i'm quite impressed
« Reply #70 on: April 14, 2014, 10:20:38 AM »
That case saver is a beast!
« Reply #71 on: April 14, 2014, 11:11:13 AM »
Quote from: havinnoj;31467
Sure looks sweet. Are they available for 14 tooth sprockets?
« Reply #72 on: April 14, 2014, 11:28:56 AM »
Quote from: Tbone07;31458
Holy Freakin Crap!!! That's a freaking case saver! Good lord, I didn't realize that made such a monster. lol!
« Reply #73 on: April 14, 2014, 11:37:20 AM »
I didn't even know upp made poly case savers for the R. How much did it set you back?
All the intake manifolds I have for my 38/39 carbs are from upp. All were good except for the last one I bought. The hole for the carb was a little off set. So one side was really thin. And the rubber had small holes in it like air was in the rubber while it set.
« Reply #74 on: April 14, 2014, 11:59:16 AM »
It's a monster lol. I think it will be perfect and I wouldn't hesitate to buy another one. I think a lot of cases could have been saved if they had this to protect them. Those little aluminum savers don't do squat
I think the case saver was $59.95, it's on UPP's site if you need to check it out
