Author Topic: what to do with "danger russ" repaired frame?  (Read 9709 times)
Offline atvmxr
« on: September 17, 2013, 11:20:45 AM »
I got a basket case R on the cheap and the frame is in worse shape than I thought.  someone re-engineered the motor mounts with angle iron on top and some additional metal hanging down below.  The back area between the lower a-arm mounts is rusted through and the shifter side frame down tube where the lower subframe is c[ATTACH=CONFIG]1895[/ATTACH][ATTACH=CONFIG]1896[/ATTACH][ATTACH=CONFIG]1897[/ATTACH][ATTACH=CONFIG]1898[/ATTACH]ompletely cracked off.  is there a way to cut this out and fix it?  should I just toss the frame in the scrap pile?  thoughts?  :confused:
« Last Edit: September 17, 2013, 11:42:39 AM by atvmxr »
Offline chrisr
« Reply #1 on: September 17, 2013, 11:33:26 AM »
I would trash it and get a good frame off here or ebay.  If the frame is probably tweaked and will have to straightened back out to repair.  I'm sure it can be repaired but after the time and money spent to repair someone else's mess you could get a good frame.
« Reply #2 on: September 17, 2013, 11:38:11 AM »
Weld the serial number to an aftermarket frame. :ride:
Offline atvmxr
« Reply #3 on: September 17, 2013, 11:44:36 AM »
[ATTACH=CONFIG]1899[/ATTACH][ATTACH=CONFIG]1900[/ATTACH]
check out the custom front motor mounts!!
[ATTACH=CONFIG]1901[/ATTACH]
« Reply #4 on: September 17, 2013, 12:25:42 PM »
Yikes!!!!!! That is ugly. :nightmare: We in the south, have a name for that type of engineering. :afro:
« Reply #5 on: September 17, 2013, 01:57:53 PM »
I have repaired the front part where is rusted through. But that break at the tube bend at the swinger area is alot of work to repair. Kinda looks like Junes bike. He bought another frame instead of trying to fix the unfix-able.
Offline trx88
« Reply #6 on: September 17, 2013, 02:47:33 PM »
ethnically engineered
Offline trx88
« Reply #7 on: September 17, 2013, 02:48:13 PM »
not very pc f red
« Reply #8 on: September 17, 2013, 09:11:05 PM »
When I first saw the break at the sub frame, I was thinking "great time to add a detachable sub frame"....only set back is there is no where to attach it to...
Offline atvmxr
« Reply #9 on: September 18, 2013, 09:29:55 AM »
Tony, you can have the front motor mounts to copy for an ultra beefy option  :congratulatory:
I guess I'll post the frame on the other site to see if anyone wants it.    Sometimes I see people looking for junk frames so they hack out a misc part they need to fix their frame.   I got this one for the motor and pipe, will probably attempt to part out the rest of this jalopy
Offline csides66
« Reply #10 on: September 18, 2013, 11:14:21 AM »
Quote from: atvmxr;12519
If you part it out let me have first crack at the Thumb Throttle and cable (if it has one).
« Reply #11 on: September 18, 2013, 11:23:22 AM »
Thats ok, I will pass.   Looks like an attempt to keep the motor in place as everything else breaks away.  If you have the 88-89 frame many people are interested in the tube that the swingarm connects to. Same with the lower mounts the front motor mounts bolt to, if they are not already broken.
« Reply #12 on: September 18, 2013, 01:10:02 PM »
Yea man chop it up and use it as an organ doner. Tony helped me in this situation once. Give life to other frames.
« Reply #13 on: September 18, 2013, 04:00:06 PM »
Offline jamieg45
« Reply #14 on: September 18, 2013, 05:51:47 PM »
Heck send the frame to tony so he can possibly make that rear upper motor mount for the 86-87 frames so you can run a 88-89 swingarm. And maybe make some lower motor mounts also.
01 Lsr 250r
00 Walsh 250r
