Author Topic: 2009 Can Am DS 450XMX Built.  (Read 2872 times)
« on: September 18, 2013, 01:51:15 PM »
2009 DS 450 XMX
Mods
Engine:
CP 13.6:1 Piston
Dual Exhaust Cam (3 degree retard)
50mm bored TB/Green Injector
Full MotoWorks Pipe
BCS Filter/Inlet Ring
BCS Oil Squirter
Updated Cases
BCS chain Guard
BCS updated Crank
BCS Radiator upgrade
BCS Tuned ECM
BCS Race Harness
BCS Epoxyd/decked Head
BCS Stainless steel valves
BCS lightend flywheel
BCS Battery Box/New Battery
Brand New Transmission
NGK spark plug wires
NGK Iridium Plugs
Piston/Crank/Clutch, Valves have approximately 10 hours on them.
Transmission has less than an hour
Chassis:
Custom Axis LT Piggy back PRS fronts
Custom Axis Rear
Precision Pro Stabilizer
Houser +1 Stem
Rath Monster Peg Nerfs
Dominator 2 Axle
BCS Double row bearing carrier
Lowered Subframe
CR21 Hip guards, master cylinder Guards, Pull rod
DWT Champions in a Box
Tag Handlebars
Tag Push Bard
PRM Grab bar
Power Madd Hand Guards
Honda Front Master Cylinder
Custom Hump Seat cover
Brand new transmission
TRX450R rear brake conversion/with brake rotor guard.
Theres probably a bunch more im missing.
Comes with the following spare parts.
XMX A-Arms
XMX Steering Stem
XMX Axle
Brand New Clutch
Stock Nerf bars
Stock radiator
Stock Exhaust
Spare motor in parts (every think is there, needs crank, piston, cases welded)
Looking to sell or trade for a equivalent built honda TRX 450R .
