Author Topic: LRD TRX 250B Pipes  (Read 75577 times)
Offline jamieg45
LRD TRX 250B Pipes
« Reply #15 on: September 20, 2013, 10:29:05 PM »
Quote from: ledperformance;12696
Please call me. I think that combination is a great idea.
Thanks for taking time out of your day and talking with me Arlan, and hopefully we can do a engine in the coming future. Have a good one and keep up the good work sir.
01 Lsr 250r
00 Walsh 250r
Offline Victork
LRD TRX 250B Pipes
« Reply #16 on: September 21, 2013, 07:38:41 AM »
My experience with the LRD pipe on about 3 or 4 motors is this, it is a fantastic woods pipe and i love it in everything from technical to fast open trails. Not so good for apllications wanting focus on top end. As far as bottom-mid i have been completely happy. I would not hesitate to use this pipe on a gncc R!
Offline atvmxr
LRD TRX 250B Pipes
« Reply #17 on: September 23, 2013, 11:07:14 AM »
Quote from: ledperformance;12666
We have stampings for LT 500 pipes. We just need a quad to fit them so we can build fixtures.
I'll spread the word to my zilla forum and see if anyone is nearby!
Offline RyanWsly
LRD TRX 250B Pipes
« Reply #18 on: September 23, 2013, 05:16:51 PM »
Can you compare the LRD pipe to your LED pipe? As why should one buy the LED over the old LRD or why one should go with the LRD over the LED.
Offline ledperformance
LRD TRX 250B Pipes
« Reply #19 on: September 23, 2013, 08:35:02 PM »
They are very close. The LED pipe is hand coned and is the C version that I built in 1998 or 99. The C pipe is similar to the B, but adds a little more top end. We do not plan to build the LED 250C pipe except for special order untill the 250B stamping are all gone. The C was the next revision of the B pipe, but never went into production untill I built a few of then starting in 2008.
Hand cone pipes are very labor intensive to build. They generally make more power than stampings.
The LRD 350 D pipe is a very good pipe also. The newer LED 350G pipe has a bigger head pipe and a fatter center section. The muffler is different also. We use a nozzle system in the muffler to more precisely control exhaust temperature in the pipe. The Hand coned LED pipe makes more peak hp than the old 350D but not enough to justify buying it if you have a good 350 d pipe on your Quad. The LED muffler would increase the power if you added it to the D pipe.
Offline Bigred
LRD TRX 250B Pipes
« Reply #20 on: September 29, 2013, 11:17:29 AM »
Arlen do u have any pics of how close the pipe us to the frame in the front where it comes around by the a arms?  I mounted my steering stabalizer down there and wsnted to see if there was room with this pioe also how much is shipping I have my cash finally
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
LRD TRX 250B Pipes
« Reply #21 on: October 02, 2013, 07:45:58 PM »
Here are some pictures of the pipe mounted in the frame. Shipping is usually around $20.
Offline Vroomy
LRD TRX 250B Pipes
« Reply #22 on: October 18, 2013, 08:04:03 PM »
just wondering what the price on postage to Australia would be for a full exhaust system? (regular and express) thanks
Offline Bigred
LRD TRX 250B Pipes
« Reply #23 on: October 18, 2013, 09:48:51 PM »
I know ve asked a lot of questions but how dose your pipe compare to a FMF fatty.
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
LRD TRX 250B Pipes
« Reply #24 on: October 19, 2013, 11:26:42 AM »
Because the FMF pipe starts making power later it does not accelerate as well as the the LRD/LED Exhaust. For example on dyno test done with the Niks 250 PV engine the FMF pipe made about 10 hp less at 6000 rpm. The sparks MX pipe also made about 8 hp less. At 7000 rpm the the LRD pipe leads the FMF by about 7 hp. At 7500 rpm the LRD leads by about 6 hp. Comparing peak hp the LRD made a little over 2 hp more than the FMF. The FMF reved out farther. The FMF peaked about 400 rpm later.
This test was done in 2001 on a 265 PV engine I did for Keith Little. This was when we were doing engines for the Nac's team. Because I was focused on acceleration we concentrated on the low and mid range power. As the season progressed we increased the top end power and rev out so the engine would rev and peak at a higher rpm when retaining the same great acceleration. We would slightly alter the port timing for different tracks.
These test were done with exhaust port timing set with gate valve up of 192'. the sub ports were lower and the highest transfer was 126'. Compression was at 235 psi.
Remember its all about the combination. Pipes work the best in the combination they are designed for.
Offline Bigred
LRD TRX 250B Pipes
« Reply #25 on: October 19, 2013, 11:37:32 AM »
Ok thanks ya im not concerend on peak hp I want usable hp
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Bigred
LRD TRX 250B Pipes
« Reply #26 on: October 19, 2013, 11:38:12 AM »
I shoulda just bought the pipe when I had the money lol leason learnd the hard way again lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline Redrider9982
LRD TRX 250B Pipes
« Reply #27 on: February 09, 2014, 02:31:22 PM »
I just got one if arlans 350g hand coned pipes its not in the frame yet still lots of snow here but its a pretty sweet lookin pipe and it dwarfs my old fmf gold series in size
LRD TRX 250B Pipes
« Reply #28 on: February 10, 2014, 11:55:27 PM »
I have a unported ct330 motor. what one of your pipes do you think would work good on this setup for dunes. I plan on talking to you when I need to go next bore size about porting it for the same.
LRD TRX 250B Pipes
« Reply #29 on: February 11, 2014, 10:30:14 AM »
I would recommend our TRX 350G pipe and silencer for that combination.
