Author Topic: Update from Power Apt on cast smart carbs  (Read 72762 times)
« Reply #120 on: June 19, 2014, 07:53:07 AM »
Quote from: christph;37070
Is difficult starting and flooding a common problem on the Smart Carb?  I was thinking about ordering one but now I'm having second thoughts.
The flooding did happen occasionally on the old billet versions, but I haven't heard or experienced any on the new cast versions or billet versions.
Offline Sky
« Reply #121 on: June 19, 2014, 09:36:50 AM »
Quote from: Jerry Hall;37051
Remove the spark plug, turn switch off, put it in 1st or 2nd gear, hold the throttle wide open and push it about 30 ft.  The flood should be cleared unless the pipe is full of fuel.
Never heard of the Jerry. Thanks for the info. I will remember that.
« Reply #122 on: June 19, 2014, 10:42:50 AM »
Quote from: Sky;37089
Its hard to do with paddle tires on so I am going to grab the knobbies and give it a try this morning.
« Reply #123 on: June 19, 2014, 10:55:23 AM »
Yes..The carbs appears to still have some design problems and it is a common consensus they are still having quality control problems in their manufacturing processes.
« Reply #124 on: June 19, 2014, 11:07:55 AM »
Quote from: Jerry Hall;37095
You say this is a common consensus. Among whom? The common consensus among those who are running them on 250r's is that they work just fine. The common consensus among the largest group that has purchased these carbs, which would be the dirt bike market is also that the carb they received work just fine. Yes, there was a small percentage that have had issues in the beginning, but only a small percentage, not the majority.
« Reply #125 on: June 19, 2014, 02:22:13 PM »
OK so heres a pic of me working on the smart carb
when I put the tank and plug back in it actually tried for the first time since January. But would not start. Waited 15 minutes and almost started. Waiting..................Try again!!!!!!!!!Yes, my registration is expired got a new tag yesterday.
« Reply #126 on: June 19, 2014, 02:32:55 PM »
Ok, it  finally started. I have one day before hitting the dunes. I am so happy I could just have a beo. Beers down and I just had to set the idle a little lower. Took for a spin in the parking lot but cannot get out of second gear. But what is great is the throttle is crisp and clean opening up in second gear. This is where my Kiehien wants to about blubber. Am very excited about hitting the dunes this weekend.
Oh yeah, this is a 431 Puma dune ported by Pete at Hybrid engineering.
« Last Edit: June 19, 2014, 02:48:31 PM by Pumashine »
« Reply #127 on: June 19, 2014, 03:13:52 PM »
Waited a little bit and started her back up. Normal 2 or 3 kicks. Definitely have the bottom end power I never had before. Like turbo in 2nd gear. Freakin scary
« Reply #128 on: June 19, 2014, 03:27:14 PM »
Quote from: Pumashine;37112
I think you got it now, Tony. Hold on tight! lol
« Reply #129 on: June 19, 2014, 03:32:49 PM »
Quote from: rablack21;37114
Yes Ryan, I about gave up on this thing. But I convinced my self if you can do it I should be able to figure it out. Day 3 and its just gonna get better.
« Reply #130 on: June 19, 2014, 03:47:56 PM »
Quote from: Pumashine;37116
Yes, if a retard like myself can do it, surely someone of your caliber and expertise can make it work. :newhere:
« Reply #131 on: June 19, 2014, 04:13:02 PM »
Quote from: rablack21;37117
I was just messin with ya. When you take on a new product its like you have to read the directions 3X to get it right.
Offline Quinnlt4
« Reply #132 on: June 19, 2014, 05:40:59 PM »
What size carb are you using on the 431?
1986 Laeger wannabe
« Reply #133 on: June 19, 2014, 06:04:37 PM »
The 40mm billet version. Oldschoolr let me borrow while he is doing his rebuild.
« Reply #134 on: June 19, 2014, 06:15:29 PM »
Thay things a beauty Clark!
