Author Topic: Coolant leak  (Read 3585 times)
Offline zarathos
Coolant leak
« on: October 01, 2013, 10:54:16 PM »
So when I bought jewel it had a coolant leak under the water pump that the PO had slathered a bunch of different sealants all over. It still leaked, but I'm assuming less than what it did before. Anyway I finally got around to checking it out and found that the vains of my water pump are trashed and under all that sealant I found a factory looking hole (I assume its a weep hole). So am I correct to conclude it was just leaking because my water pump needed to be rebuilt?
« Last Edit: October 01, 2013, 11:11:38 PM by zarathos »
Offline zarathos
Coolant leak
« Reply #1 on: October 01, 2013, 11:01:17 PM »
Offline zarathos
Coolant leak
« Reply #2 on: October 01, 2013, 11:07:18 PM »
Offline zarathos
Coolant leak
« Reply #3 on: October 01, 2013, 11:10:32 PM »
Offline jamieg45
Coolant leak
« Reply #4 on: October 01, 2013, 11:25:00 PM »
Yes and yes bud, its pretty easy to do though just take your time and read the clymer catalog and it will help a ton so you dont mess up the seals at all on installation.
01 Lsr 250r
00 Walsh 250r
Offline zarathos
Coolant leak
« Reply #5 on: October 01, 2013, 11:45:36 PM »
Thanks Jaime!
