Author Topic: 250r motor in banshee chassis  (Read 7718 times)
Offline johnny22
« on: October 02, 2013, 10:57:26 PM »
Anyone here ever put a 250r motor in a banshee frame? Setup for full drag? Or any opinions on that thought? Just wondering
Offline Bigred
« Reply #1 on: October 02, 2013, 11:01:35 PM »
Better with the shee motor for dragging
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline johnny22
« Reply #2 on: October 02, 2013, 11:03:31 PM »
Of course. I understand that but banshee motors can also be pricy to build... kinda sorta
Offline Bigred
« Reply #3 on: October 02, 2013, 11:11:03 PM »
Ya I hear ya  I think a r chassis is lighter
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
Offline johnny22
« Reply #4 on: October 02, 2013, 11:20:59 PM »
Haha thanks big red. That'll be enough. You have already persuaded me enough haha. Im in class and bored so that came to mind
Offline Bigred
« Reply #5 on: October 02, 2013, 11:24:22 PM »
Lol
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
93 pump fuel
« Reply #6 on: October 03, 2013, 06:54:40 AM »
if you can find a banshee drag frame then its a matter of cutting off brackets for the motor and body plasitcs and  welding new engine brackets and body brackets.
guys do this all the time, allot of great looking banshee drag frames are still orig banshee frames in the back half and just get extendedout the front.
nice thing about a banshee frame is they are round tube,  I have never seen a good looking drag 250r frame that had been extended.
Offline johnny22
« Reply #7 on: October 03, 2013, 10:50:43 AM »
Yeah. I saw one place that sold them like that They would just modify the stock frame. Im guessing it wouldnt be too hard to put a 250r motor in there right? It would probably just be hard to justify substituting a banshee motor for a 250r motor
« Reply #9 on: October 03, 2013, 11:38:03 AM »
When you buy a drag frame they are mostly all the same, except for motor and plastic body mounts, they usually run a small light weight radiator not from a 250r or a banshee.
But you really should Tig weld everything and if this is a problem then just wait until you see a frame setup for a Honda, they are out there but they maybe a little pricer than a frame setup for a banshee just because there are so many.
