Author Topic: Opinions/critique on my port timing please!  (Read 8996 times)
Offline Bowtie316
« on: October 07, 2013, 06:05:58 PM »
I just checked this new motor I bought, it's an ESR 330, with a +4 crank. I wanted to check the port timing just to know what it is, I came up with 197 on the exhaust ports and 134 on the transfer/boost ports.
Also, it has a race gas dome, haven't checked yet but it is supposed to be setup at 14.5:1 UCCR.
It was supposed to be a mid-top dune port.  This is more than I was expecting, is this normal for a 330 with extra 4 mm stroke?
 Thanks for any feedback.
« Last Edit: October 07, 2013, 06:30:49 PM by Bowtie316 »
Offline big330
« Reply #1 on: October 07, 2013, 07:52:35 PM »
drag engine bud.
Offline Bowtie316
« Reply #2 on: October 07, 2013, 09:26:30 PM »
Quote from: big330;14183
drag engine bud.
That's what I'm afraid of, I have no use for a drag engine. I guess I'll try it out but will probably be looking for a different cylinder.  I wanted a good dune port, and planned on using a trx5 pipe and 38A/S carb.
Offline Wes350x
« Reply #3 on: October 07, 2013, 10:00:39 PM »
Wow, I'm surprised, Maybe call k&t and see if they remember the specs or have documents on what the timings are on the motor I specifically had that motor set up for a dune motor, 40.5 carb, and Trx-5 cm pipe.   Those seem kinda high.
1988 250R
Offline Polonda
« Reply #4 on: October 07, 2013, 10:05:47 PM »
Quote from: Bowtie316;14175
Whats the squish?  How thick is the base gasket?
« Reply #5 on: October 07, 2013, 11:43:43 PM »
sounds high expeciallyin the transfers  it was probably a stoke ported cylinder then someone added stroked crank and increased port timing even more.
are you very sure of your port timing numbers, I see many people not use a piston stop or a dial indicator to find TDC and their port timing number are inaccurate.
Offline Wes350x
« Reply #6 on: October 07, 2013, 11:55:16 PM »
Rsss, I had k&t set the motor up from scratch with a unbored and unported cylinder.
1988 250R
« Reply #7 on: October 08, 2013, 12:18:06 AM »
ok maybe double check the port timing numbers, that does not sound like typical k&t work to me. unless the wrong spacer was stuck on the motor accidentally by them or someone else.
« Reply #8 on: October 08, 2013, 12:22:38 AM »
134 sounds odd .  do you plan to ride it soon ? if so report back how it works
Offline Bowtie316
« Reply #9 on: October 08, 2013, 10:22:01 AM »
Quote from: Polonda;14209
Squish was at .049.   Spacer is .197" and the gaskets are .020" x 2 of them.
Hopefully I am measuring the port timing wrong. But basically, what I posted is the amount of degrees of crankshaft rotation the ports are open before the top of the piston closes them off.
« Last Edit: October 08, 2013, 12:08:18 PM by Bowtie316 »
Offline Bowtie316
« Reply #10 on: October 08, 2013, 11:06:43 AM »
Just ran it again, tried to be a little more exact with the point the piston crosses the plane of the port roof.  Came up with 194 and 130 this time.  I used a piston stop to find tdc and found the exhaust port open at 83 degrees ATDC and the transfer/boost port at 115 degrees ATDC.  And came up with the same degrees BTDC.  That gives me 32 degrees of blow down time.  Better than what I got last time but still more than I expected.  I guess it's time to put it together and see how it does.
Offline Wes350x
« Reply #11 on: October 08, 2013, 01:39:30 PM »
Quote from: Bowtie316;14251
Damn I wish I knew how to measure port timings.. Put that thing together and ride. Let us know how it does, K&T assured me it was going to me a beast in the sand.  I hope so!
1988 250R
Offline Bowtie316
« Reply #12 on: October 08, 2013, 01:51:35 PM »
Quote from: Wes350x;14268
Yeah, I'm going to try to get it on and running this afternoon.  Still got to do a leakdown check then it should be good to go.  UCCR came out at 14.89.
« Reply #13 on: October 08, 2013, 05:16:58 PM »
Try just degreeing from TDC down to just before the ports crack open, the exhaust & then the transfers & jot those numbers down.
Offline Bowtie316
« Reply #14 on: October 08, 2013, 10:30:40 PM »
Quote from: C-Leigh Racing;14281
That's basically what I did the last time Neil when I got 194 and 130.  I'm just going to run it and see.  Its back together now, base gaskets leaked, had to replace those and add some ultra blue because the spacer was milled rough on one side.  Also had a leak on the coolant side, into the top exhaust flange bolt. It's all sealed up tight now, both passed 30 minute leak down.  Engine is on bike, got a couple more things to button up then it's ready for some heat cycles.
