Author Topic: talked to alba about making 250r nerfs  (Read 16289 times)
Offline Sky
« Reply #15 on: August 03, 2013, 10:46:31 AM »
I would be highly interested in a set for an 86R setup. Would the foot pegs be included?
« Reply #16 on: August 03, 2013, 05:43:46 PM »
Quote from: Sky;7082
Sky, this style is a propeg setup. The foot pegs are integrated into the design.
Offline Pete362
« Reply #17 on: August 03, 2013, 06:31:12 PM »
I bolted a set on my 86 250r and they bolted right up no problem or customizing
Offline Victork
« Reply #18 on: August 03, 2013, 09:21:52 PM »
Yeah, but like in the pics, you need to make brackets to support the heel guards to the frame.
Offline Sky
« Reply #19 on: August 04, 2013, 03:54:28 PM »
Quote from: rablack21;7118
Sign me up. But Chicago to sandiego is a bit far for a mockup. Keep us posted!
Offline Victork
« Reply #20 on: August 04, 2013, 08:00:20 PM »
I just threw it out there. Unless someone near san diego comes forward willing, theres nothing to keep you guys posted about. Fortunitely its an easy install on 250r as seen in the pics above.
Offline 2k1lvr
« Reply #21 on: August 10, 2013, 06:31:04 PM »
bump
89 trx5 pipe 38as carb esr330 pv cyl ported by BUBBA RAMSEY at BHP,+4 crank,cr ign,elka front shocks,lsr axle
Offline Victork
« Reply #22 on: August 10, 2013, 09:42:27 PM »
I just bought a set yesterday. The tab on top of the heel guard is meant to mount to the plastic anyway.
Offline fx4pitrone
« Reply #23 on: August 10, 2013, 10:35:33 PM »
Do you have a pic of them mounted up?
« Reply #24 on: August 11, 2013, 09:32:20 AM »
Quote from: fx4pitrone;8026
Yes, Victork, post a pic when you get them mounted. Give us your feedback.
Offline Victork
« Reply #25 on: August 11, 2013, 12:51:35 PM »
I will but those pics were posted in this thread already
Offline Victork
« Reply #26 on: August 12, 2013, 11:43:01 PM »
Since i first asked alba about these nerfs ive explained to them the process and how easy it is to put on the R. Cody at alba put $50 in my palpal for helping him out because they werent aware before! If you guys buy a set tell them youre buying them to put on your 250r! Ill have pics of mine mounted fri night
Offline Victork
« Reply #27 on: August 16, 2013, 03:28:33 AM »
Got my nerfs today, even nicer in person. They do bolt right up. Theres only one issue i encountered, the hole under the peg where a bolt goes through to lock the nerf on the mounting plate is off. I drilled mine but i just sent cory from alba a message offering to mark the mounts where the hole needs to be drilled and send them back we will see. I think im gonna contact esr about a -1 brake lever and shifter as these nerfs sit back one inch.[ATTACH=CONFIG]1414[/ATTACH][ATTACH=CONFIG]1415[/ATTACH]
« Reply #28 on: August 16, 2013, 07:53:59 AM »
Are they lower then stock as well or stock height?
Offline Victork
« Reply #29 on: August 16, 2013, 11:11:24 AM »
They seem to be stock height but i didnt measure height
