Author Topic: sleeve issue  (Read 12019 times)
Offline hontrx265r
sleeve issue
« on: October 25, 2013, 01:55:42 AM »
Opened the intake to find this spun sleeve. We will see how the mfg handles the issue tomorrow and report back. Anyone else had this happen. Its a 310 kit. ]http://
sleeve issue
« Reply #1 on: October 25, 2013, 08:28:56 AM »
Wtf causes that?
Offline hontrx265r
cylinder
« Reply #2 on: October 25, 2013, 09:55:54 AM »
Its not a stock cylinder but I've already considered going back to one.
sleeve issue
« Reply #3 on: October 25, 2013, 10:10:12 AM »
That does suck weiner! But if that is who, I think it might be from, give him a call. He will make it right for you. :joyous:
sleeve issue
« Reply #4 on: October 25, 2013, 10:44:52 AM »
Quote from: hontrx265r;15682
There are only two things that will allow the sleeve to be in the position shown.  It was installed that way or the interference fit was too loose.  Either way.......there is no excuse for shoddy workmen ship.
I cannot see how far the sleeve has rotated.  If it has rotated too much, the piston rings may be snagging in one of the transfer ports.
sleeve issue
« Reply #5 on: October 25, 2013, 11:34:40 AM »
first vid is explanatory and a bit funny.  second vid has a remedy/insurance policy on the resleeve.
http://www.youtube.com/watch?v=ghlbCaZQjDc
http://www.youtube.com/watch?v=yCSKfLarKR4
Offline hontrx265r
sleeve issue
« Reply #6 on: October 25, 2013, 02:13:23 PM »
Jerry I was going to bring it over to you but I'm going to give the mfg a chance to make it right. I spoke with them this morn I'm going to send it out this afternoon.
sleeve issue
« Reply #7 on: October 26, 2013, 02:32:17 AM »
tool marks in the aluminum appear to match whats on the sleeve. im thinking it was put in that way
Offline hontrx265r
sleeve issue
« Reply #8 on: October 26, 2013, 02:58:42 PM »
I think your seeing the reflection in the sleeve. I'm 99% sure this is a fitment issue and it rotated while running. I'm right with jerry on the incorrect interference fit. Pretty sure it will arrive to them on monday so I should have some news soon.
sleeve issue
« Reply #9 on: October 26, 2013, 03:11:18 PM »
you got the jug in your garage. what better view can you get. if the tools marks match whats on the sleeve then obviously it was installed like that. if they dont match then probly it rotated
Offline hontrx265r
sleeve issue
« Reply #10 on: October 26, 2013, 05:04:05 PM »
The tool marks on the cylinder are reflecting on the face of the sleeve, the tool marks on the edge of the sleeve match the porting on the cylinder, it rotated
sleeve issue
« Reply #11 on: October 26, 2013, 08:44:49 PM »
i looked at it again and see what you meen. the reflection is exact opposite of the cylinder tool marks which makes perfect sense.  appears to be rotated for sure.
sleeve issue
« Reply #12 on: October 27, 2013, 12:56:38 AM »
Quote from: jcs003;15700
If the interference fit is correct "pinning" the sleeve is not necessary.  Pinning just make sleeve removal more time consuming if the sleeve has to be removed.  Pinning the sleeve will also add a stress riser in the top of the cylinder where ring seal needs to be at it's best.  A stress risers may cause the bore to have a slight high spot in the  bore surface when the cylinder  is up to temperature but will measure perfectly when the cylinder is at room temperature.
A cylinder that has been pinned like in the video, will usually have 2 very faint brown spots on the bore to the left and right side of the high spot.  The faint brown spots are blow by.
sleeve issue
« Reply #13 on: October 27, 2013, 07:54:25 AM »
Quote from: Jerry Hall;15836
this may be true of an aluminum sleeved cylinder but in an iron or steel sleeve it will not create any localized stress unless the tapered pin forced deep into the mating surfaces.    also, in an aluminum sleeve it transfers the heat at the same rate so a sleeve sliding in the bore is unlikely if the fit is per manufacturers fit tolerances.
Offline hontrx265r
sleeve issue
« Reply #14 on: October 27, 2013, 12:44:43 PM »
Jerry, this motor has a ka4...4 rod in it, is this the old cr250? has wide wrist pin compared to my 88 crank.
