Author Topic: Exhaust for 510 Sabertooth  (Read 14017 times)
« Reply #30 on: October 31, 2013, 04:18:26 PM »
tony that quad is the image of perfection.
Offline JFMachado
« Reply #31 on: October 31, 2013, 04:42:12 PM »
Quote from: Pumashine;16212
Assembling the slingshot is usually done on the bench when you can set your cases on a couple blocks sideways. After the motor is installed on the bike you turn the bike on its side to disassemble the clutch. The front handlebar on a step stool works good.
O no the motor was out of the bike on the bench I just didn't know there was all those balls in there so when I tilted it forward to get the plate off I found out real quick there was lol
Offline JFMachado
« Reply #32 on: November 01, 2013, 01:45:14 PM »
Ok need a few parts to finish my 510 Sabor rebuild and 330 stroker. Got the Sabor all rebuilt but need the sleeve after the starter gear that goes between the clutch cover and starter gear on both motors with thrust washers. I need a nice shift drum that shifts smoothly. Along with 2nd gear and the thrust washer that goes after it. Also need a 88/89 swing arm bushing and the steal mounting bushings for pep shocks to mount them to the a arms and upper frame mounts. Let me know what you have.
Thanks John
PM, email, call/text
Email- Speedking86@gmail.com
Cell- 209-456-3311
