Author Topic: gear oil & stator!!!  (Read 3930 times)
Offline rande
« on: November 02, 2013, 01:45:31 AM »
Pulled my stator cover and gear oil or transmission oil poured out why????
Offline PORTED R
« Reply #1 on: November 02, 2013, 02:11:09 AM »
If its gear oil then its ur counter balancer bearing holder oring
McCoy ProX 350 5mil Duner
Offline rande
« Reply #2 on: November 02, 2013, 02:18:05 AM »
It's a easy fix that might be why it cuts.out on high revs When racing
Offline PORTED R
« Reply #3 on: November 02, 2013, 04:30:49 PM »
Ya real easy fix
Just use a lot of grease when installing
I've torn two on brand new rebuilds
Grease on oring and on the outer rim of case
Pop in slowly
Offline rande
« Reply #4 on: November 03, 2013, 01:39:20 AM »
Do i just remove flywheel and the Pick Coil and the boots that hold it in nothing to time is There ?
Offline PORTED R
« Reply #5 on: November 03, 2013, 02:38:55 AM »
Yup remove flywheel ,pickup
Then remove the three bolts holding it
Be carefull the those bolts like to snap
I haven't had that issue ,but others have
It's a little tricky pulling it out from that side but it can be done
Get a rubber mallet
Pair of vice grips
Place the vice grips on the holder with a rag in the jaws so it doesn't bend or put marks on the holder
As ur pulling on the holder ,spin it with a rubber mallet and it will pop out
Lots of patiences
Offline PORTED R
« Reply #6 on: November 03, 2013, 02:42:29 AM »
No timing to deal with
Just align the key on crank with slot on flywheel
Offline rande
« Reply #7 on: November 03, 2013, 12:25:59 PM »
Ok sounds easy im but a cr ign while its off Thanks do you know  What size o ring it is and type?
Offline PORTED R
« Reply #8 on: November 03, 2013, 04:53:15 PM »
Get it from Honda
It sits in a groove around the whole holder
I'm pretty sure its a buna type
But u can always use a viton
On the cr ignition there is timing
I don't have one,hopefully someone well chime in
Offline rande
« Reply #9 on: November 03, 2013, 06:31:19 PM »
I was going to use vitron o ring i can get them cheaper and faster but my cases Were split back in june and they but new o rings in im not sure How many Are in there and what ones the changed out . But Thanks PORTEDR for you help im Getting à puller in the morning and the local shop so i can ride again
Offline PORTED R
« Reply #10 on: November 04, 2013, 01:12:59 AM »
No problem man ,anytime
Best investment u can get is a Manuel for the 250r
Offline rande
« Reply #11 on: November 04, 2013, 01:06:46 PM »
Yea need one
