Author Topic: TIG filler material for case repair - recommendations  (Read 3024 times)
Offline ballz338
« on: November 04, 2013, 12:59:15 PM »
Do any of you guys have recommendations for what filler material to use on OEM 250R engine crankcase repair?  I am TIG welding up a crack around the shift shaft seal area.
So far i have experimented with 5356 filler rod on a junk case.  I didn't see any issues with this material but wanted to see if anyone here has experience with this.  I will also have to machine this after the welding is done.  If I remember correctly 5,000 series aluminum is not the best for machinability.
Any input is appreciated.
« Reply #1 on: November 04, 2013, 02:37:31 PM »
Quote from: ballz338;16485
I would use 4043 on any area that requires strength on a die cast case.  The 4043 is a little more flexible and not as brittle.  4043 typically does not machine as well.
If I am welding up a gasket surface I will use 5356 because it is leaves a harder surface and better surface finish.
Get all surfaces clean and a bright finish left by a carbide burr.  Do not try to weld an aluminum surface that has been cleaned by sand-blasting or sanding!!!
« Reply #2 on: November 04, 2013, 06:28:23 PM »
Seems like 4043 is just ol faithful in aluminum welding, it's pretty much all I've used, tig or mig.
Offline ballz338
« Reply #3 on: November 05, 2013, 09:23:22 AM »
Thank you both!
I am going to go with the 4043.
