Author Topic: atc250r duner project.....  (Read 58470 times)
Offline fourtrax
« Reply #30 on: December 01, 2013, 01:55:16 PM »
Quote from: Pumashine;18845
Yes, you have the flat spherical bearing at the end of the push rod. That means its the 89 version.
Hey thanks, One more thing not to worry about!!
Offline fourtrax
« Reply #31 on: December 08, 2013, 10:54:17 AM »
I have been polishing my caliper, not as bad as I first thought... I will post pictures when I'm done with it.. I saw this locknut on ebay a while ago and really liked it, so this week I ordered one, I really like it!
Offline KASEY
« Reply #32 on: December 08, 2013, 07:54:21 PM »
the only thing about the bling on the axle,,, it gets sandblasted pretty fast if your an aggressive rider,,,
Offline jamieg45
« Reply #33 on: December 08, 2013, 11:39:28 PM »
Man that thing is gonna be one big shine on the dunes man. looking good so far can't wait to see it finished.
01 Lsr 250r
00 Walsh 250r
Offline Sand_Blaster
« Reply #34 on: December 18, 2013, 12:36:09 AM »
Any updates?
87 Trx250r & 99 Banshee
Offline fourtrax
« Reply #35 on: December 19, 2013, 10:19:01 AM »
Well......It has been super cold in my workspace, no heat. I have been doing alot of this...haha
Offline fourtrax
« Reply #36 on: December 21, 2013, 01:13:34 PM »
Well warmed up a bit and was able to do a little work..I wanted to share something that was kinda funny... I needed to find some bearings for my stock chain rollers because they looked really good still and I wanted to use them. The bearing size is the same as a skateboard and rollerblade bearings...608's. Anyway I found a set of 8 bearings for 3.84 shipped to my HOUSE. This is 2 sets the sheilds are red too....the little bracket got painted..cleaned up the bolts..
Offline fourtrax
« Reply #37 on: December 21, 2013, 01:17:06 PM »
I put new seals in my caliper and put the pistons in, I did the final polish on it.......I plan on using some blue anodized bolts to show some contrast. I'll get better pics when I can push it outside...its rainin....yuck.
Offline fourtrax
« Reply #38 on: December 21, 2013, 01:46:05 PM »
I installed my lock nut on the axle....it seems the threaded sleeve is a tad short, it looks like the 85 version is different.  The one I have is 30mm wide, if someone reads this and has a trx sleeve lying around....can you measure it for me?? thanks
Offline fourtrax
« Reply #39 on: April 18, 2014, 06:16:37 PM »
Update, I'm working on the cases currently...needed a spot weld  or two several new bearings and a bead blasting and paint. The cases should go together in a week or two. I am boring my cylinder to 87mm with new wiseco. I scored a nice low hour crank.  One of my biggest problems has been finding a shock shaft in good order...rusty, rusty. I am going to send one to the west coast and have one ground and rechromed. I have plans to buy a new radiator after seeing how cheap they are. More updates asap..
Offline jadleybray
« Reply #40 on: April 19, 2014, 04:53:31 AM »
Lookin good.  I sure enjoy the process too, one piece at a time! !
« Reply #41 on: April 30, 2014, 08:16:50 PM »
This is turning out pretty good. Hope theres more updates soon
Offline fourtrax
« Reply #42 on: June 07, 2014, 07:50:22 PM »
Offline fourtrax
« Reply #43 on: July 06, 2014, 11:59:53 AM »
So I've been buffing on my tank for 2 weeks it seems...I'm to the point that I am happy. I used 600 grit and wet sanded..then used a 6" bottet in my drill with chrome polish, mothers polish and some car polish turned out much better than I ever thought possible..topped it off with a new cap and bam!!
Offline kb250r
« Reply #44 on: July 06, 2014, 08:27:21 PM »
That's a nice bike,good work all the way around....
Atc - 350 6mill
Atc - 350 4mill
Trx - 431 puma
Engineered by C-Leigh Racing
