Author Topic: Radiator hose setup  (Read 9817 times)
Offline zcarlson12
Radiator hose setup
« on: November 18, 2013, 06:38:28 PM »
I bought a brand new set of ASI hoses a while back, put them on and had no issues with fitment or overheating. Started reading about how critical engine temperature is and the problems that can arise if you don't catch overheating soon enough. I am getting a ESR temp gauge soon and already bought a Pro Design super cooler but in the directions for the super cooler it says only put in the hot water return line. How do you guys run a temp gauge and cooler on your R's? It looks like both will fit on the hose coming from the head to the top inlet on the radiator but I was curious to see what other people were doing as far as setup.I've never had a problem with overheating but than again I've never had a gauge to see what the actual temperature is.  If anyone has pictures that would help a lot as well, thanks.
Offline JR250R
Radiator hose setup
« Reply #1 on: November 18, 2013, 07:44:32 PM »
I plan on doing this as well, I hope some pics and good info gets posted.
Radiator hose setup
« Reply #2 on: November 18, 2013, 08:42:23 PM »
you want the temp gauge in the line where water exits the engine. most hondas im aware of its the head.  cant help you on the super cooler thing cuz i have no idea what it even is.  never hurts to have a fan if you got the power to run it. anything to keep the cylinder colder especially on a cylinder reed where its more exposed to combustion heat. hot air aint good for power
Offline zcarlson12
Radiator hose setup
« Reply #3 on: November 18, 2013, 08:59:21 PM »
Sorry if that was hard to understand. I know that the line coming off the head going to the top inlet is where the hot water return is I'm just asking if anyone had any tips or pictures of how they had ran the line with a temp gauge and billet cooling insert. You wouldn't want to put the insert before the temp gauge because that would alter the reading I would think.
udkm- this is what it looks like
Offline Wes350x
Radiator hose setup
« Reply #4 on: November 18, 2013, 09:25:39 PM »
I'd say ditch the inline cooler and install the temp gauge in the upper hose
1988 250R
Offline zcarlson12
Radiator hose setup
« Reply #5 on: November 19, 2013, 10:30:11 AM »
Wes- Noted
Anyone else have any input on this?
Offline jamieg45
Radiator hose setup
« Reply #6 on: November 19, 2013, 11:07:20 AM »
I would put the temp guage where the coolant returns to the head and I have seen many inline coolers installed on the outlet side. I hope this helps.
01 Lsr 250r
00 Walsh 250r
Offline atv fan 28
Radiator hose setup
« Reply #7 on: November 19, 2013, 11:16:59 AM »
inline coolers are useless IMO.
ive seen temp gauges used in both locations.
Radiator hose setup
« Reply #8 on: November 19, 2013, 11:24:13 AM »
Put the gauge in the upper rad hose coming out of the head. Engine Ice or a similier brand coolant will be more benificial than an inline cooler
Offline zcarlson12
Radiator hose setup
« Reply #9 on: November 19, 2013, 11:37:37 AM »
Jamie- That's what I figured I just wasn't sure if you could put in on the inlet side because it says otherwise in the directions.
atv fan- I agree it might not be a huge drop in temperature but I got it for $10 shipped brand new so I figured I might as well use it.
05- Thanks will do. I already put a high pressure cap on and use Liquid Performance coolant so I guess I'll just put this in the parts pile and see what temps I'm running with the new gauge installed.
Offline PORTED R
Radiator hose setup
« Reply #10 on: November 19, 2013, 12:10:32 PM »
I've seen most temp gauges ran from head to rad on the top hose
I've seen some from the waterpump to head with certain pipes ,I know with my 9 pipe it would be a tight fit
When I had a temp gauge I ran it from the rad to waterpump,probably not the best spot ,but it made it easy to look down and see real quick when duning and drag racing
McCoy ProX 350 5mil Duner
Offline Bigred
Radiator hose setup
« Reply #11 on: November 19, 2013, 12:47:13 PM »
My temp gauge is on thr hose to the waterpump and my inline cooler is on the top hose going to the head
1986 R
260cc oem cylinder
tc ported
38mm as carb
boyseen reeds
Ohlins front shocks
redone oem rear shock
93 pump fuel
cool head inline temp gauge
Offline zcarlson12
Radiator hose setup
« Reply #12 on: November 19, 2013, 01:34:04 PM »
Nice! That's what I was looking for, a couple pictures. Thanks for everyone's input.
Side note- Bigred, you putting a case saver on that R? I've never thrown a chain, knock on wood, but it does happen. I'd hate to see that nice rebuild be put back on the rack to fix the cases.
Radiator hose setup
« Reply #13 on: November 19, 2013, 01:45:25 PM »
The only problem with putting the temp gauge on the bottom hose is that you don't know what your true running temp is. If placed in the top hose, you know the temp of the coolant coming right out of the engine which is the most important.
Radiator hose setup
« Reply #14 on: November 19, 2013, 02:00:35 PM »
^^^Exactly^^^^
