Author Topic: Stock cylinder ported for low-mid range woods set-up... Who to go to?  (Read 6759 times)
Offline fx4pitrone
I am looking to have an 86 stock cylinder ported for low- mid range power.  Basically looking to get the smoothest power and most torque out of a stock cylinder.  I wanted to hear who has a low to mid range ported stock cylinder, how you like it and who did it....
I'm planning on running it on a long rod motor, spacer plate and set up for 50-50 race/93.....
If you have any other advice for a torquey trail/woods motor set up I'd love to hear it!
Thanks!
« Reply #1 on: November 19, 2013, 08:12:51 PM »
You want to send it to none other than Laz @ GThunder
Offline atv fan 28
« Reply #2 on: November 19, 2013, 08:32:07 PM »
Neil Pritchard
Offline dlunn
« Reply #3 on: November 19, 2013, 09:19:42 PM »
Quote from: atv fan 28;17853
Neil Pritchard
Agreed.  I'm running a stock cylinder ported by Neil, spacer plate, 220 lbs of compression, and the trx5 pipe and it runs really good.
Offline fx4pitrone
« Reply #4 on: November 19, 2013, 09:55:05 PM »
Thanks guys... I kinda forgot abut laz.... Neil was at the top of my list.... Followed by ken oconnor racing because he is in my backyard....
Keep the replies coming!
And I have a pwk 35 and 36... Which do you think would be a better carb for low to mid power?
Offline The_Steve_Man
« Reply #5 on: November 20, 2013, 07:03:37 AM »
I had my cylinder ported by Eric Gorr. I run a 39 pwk and ride trails all the time. The powerband hits pretty had but is manageable.
I really like my setup. Plenty of power but not so much it is unrideable in the woods.
« Reply #6 on: November 20, 2013, 09:06:19 AM »
Quote from: fx4pitrone;17859
If you want to keep the optimum low/mid power and throttle response on that OEM cylinder you don't want to go much bigger than a 36.
Low/mid power is Laz's expertise, he's been running the full GNCC series back when 250r's were still the main machine used. Hard to argue with his resume
« Reply #7 on: November 20, 2013, 09:07:12 AM »
You can also go view the GThunder section on the QuadZone forums and look at the 250r build he did for GNCC pro Jeff Pickens. He used an OEM cylinder in that build as well
« Reply #8 on: November 20, 2013, 09:25:11 AM »
If you go the 85/86 cylinder route & going to bump the compression up, best to be sure the head stay is in place to support the cylinder.
The 85/86 year 250R cylinders, were weaker casting in the reed chamber area than the 87 & up & when high compression is used, they tend to bust down the side of the cylinder casting, so that head stay must be in place to give the old model cylinders support.
Offline TRX250R1
« Reply #9 on: November 20, 2013, 07:12:29 PM »
Neil pritchard
Offline fx4pitrone
« Reply #10 on: November 20, 2013, 09:41:18 PM »
Thanks again for the replies... Neil, ill be in touch w you soon to pick your brain and go over some options....
« Reply #11 on: November 20, 2013, 11:53:51 PM »
Quote from: fx4pitrone;17848
Thanks!
What pipe are you going to run?  The pipe has a HUGE influence on the shape of the power curve.
« Reply #12 on: November 21, 2013, 02:42:09 AM »
hey whats the starting diameter on most 250r pipes ?  checked a ktm250 pipe and its 40mm which seems about right given its state of tune. wondering if a 250 tuned to the max might need a diameter closer to 50mm.  maybe they are around 50 on something like the esr11 ?
Offline fx4pitrone
« Reply #13 on: November 21, 2013, 09:17:02 AM »
Sorry Jerry... Forgot that.... I have an fmf and a trx-6 pipe.... Planning on running the esr trx 6 .....
Offline atvmxr
« Reply #14 on: November 21, 2013, 10:07:45 AM »
my old LRD motor certainly had plenty of low end for my trial riding fun
