Author Topic: '86 TRX250R Rebuild  (Read 21652 times)
Offline fx4pitrone
'86 TRX250R Rebuild
« Reply #15 on: December 01, 2013, 08:26:35 AM »
Beautiful job!  Cani ask what red pc you used?  Is it a close oem match?
Offline Turftamer
'86 TRX250R Rebuild
« Reply #16 on: December 01, 2013, 09:20:01 AM »
Quote from: fx4pitrone;18828
Thanks! The color was "Very Red" from Prismatic Powders.  I think it's close to OEM, but I don't have anything to compare to.  Primarily, I just wanted to match my plastic.
'86 TRX250R Rebuild
« Reply #17 on: December 01, 2013, 03:42:29 PM »
Nice looking build!
Offline Turftamer
'86 TRX250R Rebuild
« Reply #18 on: December 04, 2013, 09:06:53 PM »
Got the shocks cleaned up and re-assembled.
Started bolting up the front-end.  One of the stainless shock mounting bolts seized up and now I have to cut it out. :mad-new:
'86 TRX250R Rebuild
« Reply #19 on: December 04, 2013, 10:03:57 PM »
Looks great
Offline bholzgen
'86 TRX250R Rebuild
« Reply #20 on: December 05, 2013, 11:43:52 AM »
This is a very clean build.  I like it a lot!
2002 Roll Design Lobo MX
2002 Laegers CRF450R Hybrid
1985 ATC 70
Offline Pro-Fab
'86 TRX250R Rebuild
« Reply #21 on: December 06, 2013, 06:03:27 PM »
DONT CUT IT WITH A GRINDER!!! Go to sears and get the nut cracker it will save your powder.
Offline Turftamer
'86 TRX250R Rebuild
« Reply #22 on: December 06, 2013, 06:44:39 PM »
Quote from: Pro-Fab;19277
Thanks, I didn't think about that! I actually have one at work.  Probably give it a try Monday night.
'86 TRX250R Rebuild
« Reply #23 on: December 06, 2013, 06:56:46 PM »
very nice job.  the polishing is done well.
whats the reason for the upper shock relocation bracket?
Offline Turftamer
'86 TRX250R Rebuild
« Reply #24 on: December 06, 2013, 08:38:07 PM »
Quote from: jcs003;19280
To be honest, I think it was just a result of the shock being too short.  The previous owner did most of the modification and I think it was simply a matter of using what he had available.  I'm sure it's not the best setup, but for the type of riding I do (mostly trail), it works just fine.
Offline Turftamer
'86 TRX250R Rebuild
« Reply #25 on: January 12, 2014, 08:35:32 PM »
I promised myself I'd get it on the floor by Sunday night - mission accomplished!
Offline bnau267
'86 TRX250R Rebuild
« Reply #26 on: January 12, 2014, 08:44:05 PM »
Quote from: Turftamer;19288
I think they could have to do with using the trx450 rear end.  I bought a complete 06 setup and it seems like I'll need to mess with the linkage and shock mounting location to get the geometry as close to the original Honda design as possible.  I could and might be completly wrong but that's my guess...
NICE BUILD!
Offline Turftamer
'86 TRX250R Rebuild
« Reply #27 on: January 12, 2014, 08:53:13 PM »
Quote from: bnau267;22114
NICE BUILD!
Thanks.  I'm almost positive you're correct.  The rear shock overall length is about 16".  I'm not sure what a 450R shock length is, but I think this is the complete rear setup the previous owner took off his son's 450.  A longer shock might help, but I think the lower linkage to frame mount would still need modification.
'86 TRX250R Rebuild
« Reply #28 on: January 12, 2014, 09:25:13 PM »
That thing looked pretty good before.  Now it really looks nice.  Great job on the rebuild!
Offline Turftamer
'86 TRX250R Rebuild
« Reply #29 on: April 29, 2014, 08:20:04 PM »
Well, I finally filled with oil, coolant, and fuel!  Damn thing fired up on the first kick (actually caught me a little by surprise. LOL!) and idled smooth.  The only problem, center case gasket leaks.  So, back out it came.  Right now the motor's split apart and I'm cursing the cheap gasket maker I used during assembly as I carefully scrape it off, trying not to gouge the mating surface or scratch the powder coat.  On a brighter note, I got some cool bling in the mail from Pumashine.  Thanks a bunch Tony!!  :cool:
