Author Topic: Trx250r Resi clamps  (Read 58741 times)
Trx250r Resi clamps
« on: November 30, 2013, 11:28:23 AM »
The resi clamps are made from 6061 Aluminum 1/2" thick. One side has a clearance hole for a 6mm bolt. The other side is tapped for the 6mm thread Honda uses on out quads. After fabrication the part is bead blasted for a consistent bare aluminum finish. So the surface is porous and perfect for paint color of your choice. Some sort of paint is recommended to help easily clean the surface down the road.If you like the natural  look clear is a good choice. Most of you racing prefer flat black. If you want them polished you will have to let me know before ordering.
The ones below with the square OEM frame rectangular notches are designed for mounting up front between the shocks or behind the radiator. The ones with the round cutouts are for 1" aftermarket frames. You will have to measure your resi's to find out what size you need to order. So far the sizes cut are 1 15/16" or 50mm, 2" and 2 1/4". Not all resi's are the same from the same brand as well as different brands. So at this point it is best to measure your resi with a dial caliper if available and give me the dimension. Will also need to know what the frame tube size you are mounting to.
To keep these affordable the bare finished is offered a $10 a clamp. 2 clamps are recommended per resi. Shipping will be the flat rate box at $8
« Last Edit: August 18, 2018, 09:51:40 AM by Pumashine »
Offline Wolvman99
Trx250r Resi clamps
« Reply #1 on: November 30, 2013, 07:53:13 PM »
VERY NICE TONY way to go . steping up an making parts for us .i am going to need some for a round tube frame soon. i will get back too you later an get some .
Offline mrtwidster1
Trx250r Resi clamps
« Reply #2 on: December 16, 2013, 10:41:55 AM »
Sweet product! PM sent.
Trx250r Resi clamps
« Reply #3 on: December 30, 2013, 01:43:54 PM »
What you all have been waiting for Rear resi clamps. One member wants to get rid of his OEM clamp set up off the frame. So these will take the place of them on the OEM frame.
A side view to show how they line up with existing OEM set up.
Then there are the after market frames made with 3/4" tubing do these were developed. And maybe the 3 wheeler frames.
Offline trx250scar
Trx250r Resi clamps
« Reply #4 on: December 30, 2013, 08:29:52 PM »
I desperately need that for my OEM frame OEM rear resi. When I powder coated my frame I stripped all the OEM brackets off thinking I could easily find a clamp. Wasn't so easy so now I have rubber and two zip ties for a resi clamp.
Trx250r Resi clamps
« Reply #5 on: December 30, 2013, 09:19:53 PM »
Quote from: trx250scar;20994
I always build an extra set when doing the first run so I got you covered. At first I though who the heck would ever take these off. Then I remembered my brother one day cutting everything off with the intention of making it lighter. I am sure others have been damaged or broken. In time I am sure to have a stock of everything everyone needs.
Offline mrtwidster1
Trx250r Resi clamps
« Reply #6 on: January 03, 2014, 09:51:04 AM »
Got mine in yesterday! Great product and Great fitment. Mine were installed on an 85 ATC R that has the round tube frame.
Worked great and looks awsome.
Thank you Sir!
« Last Edit: January 03, 2014, 10:35:23 AM by mrtwidster1 »
Offline troybilt
Trx250r Resi clamps
« Reply #7 on: January 03, 2014, 12:00:34 PM »
I'm going to measure up my 450r frame, I think this will work for my Axis front shocks.  Nice work Tony!
Elsinore 496cc Saber
Trx250r Resi clamps
« Reply #8 on: January 03, 2014, 12:40:58 PM »
Rear resi clamp installed on OEM frame.
Offline trx250scar
Trx250r Resi clamps
« Reply #9 on: January 03, 2014, 12:50:27 PM »
When r these going up for sale. Need two for the rear pretty bad.
Trx250r Resi clamps
« Reply #10 on: January 03, 2014, 01:34:03 PM »
Quote from: trx250scar;21287
I have an extra set of the size shown above for stock frame with stock resi.Its too early to put them on the site. I have made 10 different sizes so far. Just PM me what size you need and your paypal address and I will send you an invoice. You can pay whenever you get the funds or go a different route. I know what size the stock ressi's are but each brand uses a different mold. Some brands even has 3 different sizes for different applications. Clamps are $10 each and $7 to ship. The set pictured above was $27 shipped.
« Last Edit: January 21, 2017, 04:45:29 PM by Pumashine »
Offline PDXTRX
Trx250r Resi clamps
« Reply #11 on: January 30, 2014, 08:29:39 PM »
Slick Tony.  Thank you for all your hard work.
Keeping the 250R alive through passion and perseverance.
http://www.facebook.com/pages/PDXTRX/131813700185621
Offline trx250scar
Trx250r Resi clamps
« Reply #12 on: February 16, 2014, 02:17:10 PM »
Here are the OEM frame OEM shock rezzi  clamps. Fit great look great. Thanks puma.
Offline Slavery
Trx250r Resi clamps
« Reply #13 on: August 08, 2014, 02:21:48 AM »
I would like to order a pair of these. Plese let me know how I can go about it. I am local, here in Eugene, so it would be easy and convenient! The sooner the better. Thanks
Trx250r Resi clamps
« Reply #14 on: August 08, 2014, 09:32:09 AM »
Quote from: Slavery;40566
I would like to order a pair of these. Please let me know how I can go about it.
Just have to measure your resi diameter to know what size to cut. Thr jet was down for awhile but its back up to spec. I have 3 existing orders and usually cut as many as possible in a run.
