Author Topic: 496 saber build  (Read 14707 times)
Offline johnny22
496 saber build
« on: December 07, 2013, 11:10:41 PM »
So i guess i will finally get going with this motor. It really bugs me seeing it on the shelf everyday when i get home from work.  I have a whole bunch of questions because this motor is wayy out of my league. I'll start with getting my frame up to par if thats possible with an oem frame and this motor. Im gonna double up the lower mounts so that they don't break. are those the one that normally break or should i worry about the front triangle mounts also? or anything else with the frame?
Offline atv fan 28
496 saber build
« Reply #1 on: December 07, 2013, 11:14:33 PM »
I know Shane ran his Saber in a OEM frame with stock mounts and didnt have any issues.
Offline johnny22
496 saber build
« Reply #2 on: December 07, 2013, 11:20:42 PM »
oh ok. well when i took my 370 out the other day one of my lower mounts was broken so i figured i might as well reinforce them since im gonna be welding there anyway. right?
Offline jamieg45
496 saber build
« Reply #3 on: December 08, 2013, 07:57:07 AM »
Cool man,  is this motor going in the green plastic bike bud.
01 Lsr 250r
00 Walsh 250r
Offline johnny22
496 saber build
« Reply #4 on: December 08, 2013, 12:17:01 PM »
Yes sir jamie. I put a lectron carb on the motor just to see if i could clear the frame and all. Is it gonna be a problem that it is tilted clockwise just a bit?
496 saber build
« Reply #5 on: December 08, 2013, 12:53:05 PM »
Most important issues with frames on big bores comes from the cranks not being balanced in relation to the piston. The other frame breaking problem is a misaligned CB gear. Or CB lightened too much. Last but not least is when one mount comes loose and the rest have to take the load.
Offline johnny22
496 saber build
« Reply #6 on: December 08, 2013, 01:34:37 PM »
Ok so i believe troy said the crank was balanced and by the counter balancer being misaligned do you mean the dots on the gears not lined up? Is there really a way to tell if the cb has been lightened too much?
496 saber build
« Reply #7 on: December 08, 2013, 05:15:18 PM »
Quote from: johnny22;19421
Ok so by the counter balancer being misaligned do you mean the dots on the gears not lined up? Is there really a way to tell if the cb has been lightened too much?
Yes the dot alignment. When your bike feels like a foot massager then the vibes are gonna tear the frame apart if the CB is that light.  No CB lightening for Puma or Saber. Just 370 and below
Offline johnny22
496 saber build
« Reply #8 on: December 08, 2013, 05:36:45 PM »
Ok so i'll double check the dots and make sure the bolts are tight. Does the carb normally sit a little tilted with these topends?
496 saber build
« Reply #9 on: December 08, 2013, 06:06:57 PM »
Quote from: johnny22;19445
I have not got mine yet.
Offline atv fan 28
496 saber build
« Reply #10 on: December 08, 2013, 06:10:30 PM »
my carb sits straight up.. is the carb hitting anywhere?
Offline johnny22
496 saber build
« Reply #11 on: December 08, 2013, 06:13:15 PM »
Hits the cases where the kick starter gear is. Its a lectron carb with a billet bowl
Offline atv fan 28
496 saber build
« Reply #12 on: December 08, 2013, 06:22:14 PM »
hmmm... might need to get a cast bowl from CPI
Offline johnny22
496 saber build
« Reply #13 on: December 08, 2013, 06:24:10 PM »
Ok ill look into those. You're running the billet bowl or cast one?
Offline atv fan 28
496 saber build
« Reply #14 on: December 08, 2013, 06:25:50 PM »
cast
