Author Topic: 496 saber build  (Read 14715 times)
Offline johnny22
496 saber build
« Reply #15 on: December 08, 2013, 06:51:25 PM »
Oh ok so thats probably the ticket then. Do you have a vent hose coming out of the cases under the intake? This motor has one thats plugged
Offline atv fan 28
496 saber build
« Reply #16 on: December 08, 2013, 07:12:30 PM »
is it a brass vent tube? i remember seeing some pics of it but i cant recall what it was for?? Nitrous maybe?? I would ask Troy or Dave to be sure.
Offline johnny22
496 saber build
« Reply #17 on: December 08, 2013, 07:17:42 PM »
Ok i'll ask them It just seemed odd to me that there was a plugged vent.
Offline atv fan 28
496 saber build
« Reply #18 on: December 08, 2013, 07:20:37 PM »
the brass/copper looking vent?
Offline johnny22
496 saber build
« Reply #19 on: December 08, 2013, 07:23:15 PM »
Yeah the one with the pink hose on it
Offline troybilt
496 saber build
« Reply #20 on: December 09, 2013, 03:16:24 PM »
Nitrous, or fuel pump... is what I was told.
Elsinore 496cc Saber
Offline troybilt
496 saber build
« Reply #21 on: December 09, 2013, 03:18:02 PM »
Crank is balanced and I didn't have any vibration issues.   It was smoother than I thought it would be.
496 saber build
« Reply #22 on: December 09, 2013, 05:27:23 PM »
Quote from: atv fan 28;19447
my carb sits straight up.. is the carb hitting anywhere?
Good to know. So you're running a bigger cast bowl on a Keihin or Lectron carb?  What intake boot?  I had worried a bigger bowl may cause fitment clearance issues with the case.
Offline Polonda
496 saber build
« Reply #23 on: December 09, 2013, 06:18:01 PM »
Quote from: havinnoj;19556
The cast bowl from CPI is made specifically for the Honda when running a Lectron.  It has a cut out to clear the case.
496 saber build
« Reply #24 on: December 09, 2013, 06:24:04 PM »
Quote from: Polonda;19557
Interesting. Do they make one for PWK's?
Offline Polonda
496 saber build
« Reply #25 on: December 09, 2013, 06:45:33 PM »
Quote from: havinnoj;19558
Not that I'm aware of.  Not sure a need exists for one actually.  The huge cast cowl is not needed until you get into the big Lectron carbs where lots of Alky is needed.
Offline Polonda
496 saber build
« Reply #26 on: December 09, 2013, 06:48:47 PM »
You can see what the bowl looks like here.  It has two fuel inlets and two sets of floats.  Hold lots of fuel, but will set you back $200 new.
http://trx250r.org/showthread.php?2011-New-Sabertooth-Topend-PEP-Rear-shocks-and-more!!!!
Can't really see the notch for the case in this pick though.  I'll see if I can snap a pic of mine later.
Offline Polonda
496 saber build
« Reply #27 on: December 09, 2013, 07:08:08 PM »
[ATTACH=CONFIG]2626[/ATTACH]
[ATTACH=CONFIG]2627[/ATTACH]
You can see how the corners cut off to clear the case. Mine still rubs a little due to being a Polonda with a different reed cage welded on and and a custom intake.
Offline atv fan 28
496 saber build
« Reply #28 on: December 09, 2013, 08:00:35 PM »
Im running the UPP boot and cast bowl on my Cutler carb. Mine clears the case but not by much. The Tyson frame i have was running a Puma with a Lectron carb. But with my Saber and the Cutler i had to cut the shock mount tube and move it back.
Offline Polonda
496 saber build
« Reply #29 on: December 09, 2013, 08:12:54 PM »
My Lectron barely clears the cross tube with the shock mount on a stock frame.  No way could I fit that monster of a cutler without modify my frame like Wayne did.
