Author Topic: LRD Attitude Build  (Read 164652 times)
Offline Higgy87trx425
LRD Attitude Build
« Reply #15 on: December 18, 2013, 12:16:44 AM »
Pipe problems!! Here's what I've been dealing with for the last couple of hours! Just doesn't wanna bolt up! I'm thinking of going to an exhaust shop to see if they can use a tube bender or a die on it? Its off just enough so it hits the shock mount when its bolted up. Check it out!
http://s979.photobucket.com/user/543215196/library/LRD%2010
Thanks Higgy!
LRD Attitude Build
« Reply #16 on: December 18, 2013, 12:24:04 AM »
So on another note Tony's coil mount ended working great!!!! So I got my coil mounted today! I'm still wondering if I should run that ground to the Radiator mount as reccomended last night??
 Thanks Higgy
LRD Attitude Build
« Reply #17 on: December 18, 2013, 12:54:59 AM »
Ok heres a few more pics!
 Thanks Higgy!
LRD Attitude Build
« Reply #18 on: December 18, 2013, 01:01:23 AM »
I think I figured out how to post multiple pics at once!
 Thanks higgy!
LRD Attitude Build
« Reply #19 on: December 18, 2013, 01:11:31 AM »
That thing looks killer man!  The Duncan cover does not match your LED motor.....I think you should sell it to me.:glee:
LRD Attitude Build
« Reply #20 on: December 18, 2013, 01:45:41 AM »
Quote from: red88r;20143
 Sure, I'll just need an LRD or LED cover to replace it with!
 Thanks Higgy!
Offline jamieg45
LRD Attitude Build
« Reply #21 on: December 18, 2013, 10:09:00 AM »
Nice build man, hey get with Jerry white he can take care of you pipe issue and not hurt the chrome at all. He will cut it and re angle it and all and tight it up for you bud. I think having it bent will mess up the chrome on the pipe bad man.
01 Lsr 250r
00 Walsh 250r
LRD Attitude Build
« Reply #22 on: December 18, 2013, 12:38:28 PM »
Quote from: jamieg45;20156
Yeah, I think that its something that needs to seen in person on the bike before you can make the bends/cuts! I'm not sure where jerry is, but its not too far off, just needs alittle tweeking!
 Thanks Higgy!
LRD Attitude Build
« Reply #23 on: December 18, 2013, 12:55:58 PM »
that grab bar is sweet!  is it carbon fiber?
LRD Attitude Build
« Reply #24 on: December 18, 2013, 02:10:00 PM »
Quote from: jcs003;20176
Yep, custom made RED Weave Carbonfiber. A guy on the forum made it for me about 2 1/2 yrs ago! Can't remember who did it??
 Thanks Higgy!
LRD Attitude Build
« Reply #25 on: December 18, 2013, 05:20:09 PM »
That's really wierd. Maybe talk to Arlan about it before you go cutting up that beautiful pipe? Hard to imagine an LRD pipe not fitting the LRD frame lol
LRD Attitude Build
« Reply #26 on: December 18, 2013, 11:49:22 PM »
Quote from: Tbone07;20187
 Those pipes were made for stock frames, just like everything else on this bike its a struggle, but it will be worth it in the end, and I'm gettin closer everyday!! I was gonna call Arlan today, but just got carried away and the pipe is like one of the last things that you put on your bike anyway. Plus I thought I might have more questions by the end of today anyway!
Thanks Higgy
LRD Attitude Build
« Reply #27 on: December 19, 2013, 12:09:50 AM »
So I got some more work done today, I won the 1st round and Honda won the 2nd. I got my carb and intake bolted up! The carb was tight, but it didn't hit. The rubber intake boot that connects to the carb hits the shock just a little! Then I switched to some Fast Flexx bars and hooked up the throttle cable and the Baldwin cable guide. Got my ASV front brake lever on then the shifter & Kickstarter. Tore my brake calipers apart for rebuilding and polishing and managed to break off a bolt on the rear brake mount, so tired drilling it out, but it might be a no go. We'll see tomarrow?? I may be buying a new one? Well here my 1st video I've ever taken of a build so its a little shaky, but check it out!http://s979.photobucket.com/user/543215196/media/LRD%2011/LRD11017.mp4.html
And heres some fresh pics as well
http://s979.photobucket.com/user/543215196/media/LRD%2011/LRD11010.jpg.html
http://s979.photobucket.com/user/543215196/media/LRD%2011/LRD11014.jpg.html
http://s979.photobucket.com/user/543215196/media/LRD%2011/LRD11018.jpg.html
 Thanks Higgy
LRD Attitude Build
« Reply #28 on: December 19, 2013, 12:13:27 AM »
So I got some more work done today, I won the 1st round and Honda won the 2nd. I got my carb and intake bolted up! The carb was tight, but it didn't hit. The rubber intake boot that connects to the carb hits the shock just a little! Then I switched to some Fast Flexx bars and hooked up the throttle cable and the Baldwin cable guide. Got my ASV front brake lever on then the shifter & Kickstarter. Tore my brake calipers apart for rebuilding and polishing and managed to break off a bolt on the rear brake mount, so tired drilling it out, but it might be a no go. We'll see tomarrow?? I may be buying a new one? Well here's my 1st video I've ever taken of a build so its a little shaky, but check it out!http://s979.photobucket.com/user/543215196/media/LRD%2011/LRD11017.mp4.html
 Thanks Higgy
« Last Edit: December 19, 2013, 12:42:41 AM by Higgy87trx425 »
Offline TRX250R1
LRD Attitude Build
« Reply #29 on: December 19, 2013, 08:10:25 AM »
Quote from: Higgy87trx425;20174
 Thanks Higgy!
Jerry is in Indy!
