Author Topic: Project XC 450r  (Read 44442 times)
Project XC 450r
« on: December 16, 2013, 11:23:39 AM »
Project TT 450r going under the knife. Starting with a bone stock 04 450r, transforming into a semi low budget build, but they all start out that way!!  Motor just had a new Honda updated crank, oem bearings and seals. I already have a 14.1 Baldwin JE piston, Baldwin exhaust, crf cam and possibly doing a crf450 ignition swap. Not sure on whos doing the port work yet, either Led or our local guy. Arms and swingarm yet to be determined, I would like to find some Roberts stuff but we will see how it plays out. Deuce has really got me thinking about HRE as well. Naturally a Rath swaybar. Shocks will go to Andy at Maul Tech Atv, probly have oem's built for this project, along with his rear link. Probly go white on white with this one since I never finished the Houser, and yes, my powder coater loves me..lol   Heres the one pic I have, already started tearing it down, and more pics on that later. It will be off to powder in the next couple days, depending on work. Enjoy or complain about a 4-stroke!
Project XC 450r
« Reply #1 on: December 16, 2013, 11:43:21 AM »
:boxing::sign0108::sign0108::black_eyed:
Offline Fire1
Project XC 450r
« Reply #2 on: December 16, 2013, 11:52:17 AM »
What benefits to you get from the CRF ignition?
Project XC 450r
« Reply #3 on: December 16, 2013, 11:55:23 AM »
Pretty much the same thing as doing a cr250 ign in a trx. Lighter flywheel and better timing curve. Plus I have a full crf ignition with a Sparks/Vortex 10 way cdi.
Project XC 450r
« Reply #4 on: December 16, 2013, 01:04:35 PM »
Project XC 450r
« Reply #5 on: December 19, 2013, 09:15:05 PM »
Had a free hour so this is what happened. Was hoping to have the frame to powder tomorrow but Im wiped out from work so this is as far as it got. Will be blasted, checked for cracks, welded if needed and a few unnecessary things removed to shave some weight. Going to lower the subframe 3/4" while Im at it. After xmas or when the Houser sells I will get more serious about what I will be using for suspension. Swar bar will be this weekend and possibly a stem. AC nerfs with IMS pegs are on their way. Heres how she looks now.
Offline jamieg45
Project XC 450r
« Reply #6 on: December 19, 2013, 10:04:32 PM »
Wow Eric you really don't know kw what you want, I really think know you should of kept the laeger 250r over all.
01 Lsr 250r
00 Walsh 250r
Project XC 450r
« Reply #7 on: December 19, 2013, 10:18:15 PM »
I believe I have quad A.D.D...lol.. I will build my oem 86 this spring maybe summer, will keep that a simple rider quad.
Project XC 450r
« Reply #8 on: December 20, 2013, 10:05:06 AM »
Being a 4 poker, I really shouldnt get involved, but if you want some good solid 450R advice contact Chuckie, my son-inlaw.
He finished 4th for 2013 season in the EDT Pro class.
Uses Venom Performance (John) for his engine stuff & John knows how to do a (LEGAL) 450R TT engine. Chuckie makes his own sway bars as well, CCR Racing.
Project XC 450r
« Reply #9 on: December 20, 2013, 03:58:29 PM »
Thanks Neil!!!.. I do have some guidance from a few good sources already, but never hurts to have more, Im all ears and always willing to learn!
Project XC 450r
« Reply #10 on: December 20, 2013, 10:47:37 PM »
Heading to my welder!!
Offline bnau267
Project XC 450r
« Reply #12 on: December 21, 2013, 10:51:15 AM »
Quote from: 05450r;20261
You def have ADD.  Looking forward to seeing this come together.  I got the same problem.  Maybe we should be working the assembly line at some quad factory...it would save a lot of money.
Project XC 450r
« Reply #13 on: December 21, 2013, 04:26:11 PM »
Thanks Jcs, I seen that, need one a little shorter though. Bnau, thats not a bad idea..lol
Offline DnB_Racing
Project XC 450r
« Reply #14 on: December 21, 2013, 06:06:13 PM »
for the crf ignition swap were are you getting the adapter plate from are you making this yourself or having one made ?
and you will also need to machine down the stator cove some, but that shouldn't be much of an issue also if I remember correctly you will need to have the flywheel machined also...
I know Dasa does this but im sure there are a few more, maybe BCS
