Author Topic: 2007 CR Ignition from ESR?  (Read 15326 times)
« on: December 25, 2013, 07:03:57 PM »
Anybody have experience or more info on this?  Haven't seen one of these boxes tested either - anyone know the timing curve?
Honda TRX250R CR250 2007 Ignition
Offline Brett
« Reply #1 on: December 26, 2013, 12:00:19 AM »
Quote from: havinnoj;20691
I too am curious about this. Might have to sell my 2001 ignition to fund this
-Brett-
86 TRX250R
Offline Vader
« Reply #2 on: December 26, 2013, 12:02:33 AM »
Quote from: Brett;20694
-Brett-
I'd stick with your 2001 cr ignition vs. buying this, presuming that's what you have.
85 Missile 310R Duner
86 ATC 330R Duner
88 TRX 350R Duner
06 LTR 535 Duner
« Reply #3 on: December 26, 2013, 12:33:10 AM »
Not sure I'd sell a 2001 to try a 2007..
Quote from: Vader;20695
Have you tried a 2007 Vader?
Offline Brett
« Reply #4 on: December 26, 2013, 01:36:59 AM »
Yes sir, Bought it way back in 2008. single best mod I did to my R. I just assumed newer was better, even though they are both a digital ignition
-Brett-
86 TRX250R
« Reply #5 on: December 26, 2013, 06:04:09 AM »
wow!  thats quite a bit more expensive than the 2001 cr250 ignition.  i paid $490 new for the  2001, 4 years ago on sale.
« Last Edit: December 26, 2013, 08:57:57 AM by jcs003 »
Offline TRX250R1
« Reply #6 on: December 26, 2013, 08:42:31 AM »
WoW!  I guess I'd better jump on the next used 01 I see for sale.
Offline fast350r
« Reply #7 on: December 26, 2013, 09:24:00 AM »
the 2001 still has the best curve for our 250r engines, there are alot more components in play with the 2002 or never cr ignitions due to power valve connections integrated in the harness. the 2000 or 2001 ignitions are no longer available new from Honda , Bdt is probably the only place you can still buy one. You can also look around on craigslist for cr part outs, and buy them cheap. i just bought 2 ignitions yesterday all complete.
Shearer 431 puma
« Reply #8 on: December 26, 2013, 09:28:14 AM »
Don't forget about the CR500 ignitions from Service Honda. I believe RSSS396 did a write-up on this not too long ago. I'll have to find it
I can't believe the cost of the '07 kit. That's bullshit
Offline fast350r
« Reply #9 on: December 26, 2013, 09:43:03 AM »
yea 739 is steep
Shearer 431 puma
« Reply #10 on: December 26, 2013, 10:25:20 AM »
When you look at that link posted that is what you should expect the parts of a new Genuine Honda OEM ignition kit to look like, in Honda OEM Factory packaging. It is too bad that the price went up but I believe it is only 40.00 more then the 700.00 ziplock and saran wrap 01 being sold. If you are going to buy a new kit the 740.00 07 vs the 700.00 01 doesn't seem to sting as much as it would if the 600.00 01 kit was still available. Another thing about the newer kits is that in the future you will be able to get a genuine honda replacement component if you ever need it.
« Last Edit: December 26, 2013, 01:33:59 PM by etccb »
Offline fast350r
« Reply #11 on: December 26, 2013, 10:37:04 AM »
there is an 03 ignition on feebay right now for 215 dirt cheap , it is complete all u need is eddies 02 to 07 adaptor plate he has for sale online.
Shearer 431 puma
Offline fast350r
« Reply #12 on: December 26, 2013, 11:52:21 AM »
just thought i would post ,there is a 2001 cr ignition on ebay item number 390732973129 its the full harness, stator, flywheel , and cdi ,,,, NO COIL
Shearer 431 puma
Offline Vader
« Reply #13 on: December 26, 2013, 01:19:25 PM »
Quote from: havinnoj;20698
No, but I have a complete spare 02 CR 250 ignition w/ timing plate.  I lent the 02 to rsss396 to test a few months ago and he did a thread on it.  The thing I like about the 00-01 ignition is the simplicity.  The 02 has additional wiring and a larger CDI that make it less compact and messy to mount up to an ATC.  The TRX would be easier to mount up an 02-07 though.
Instead of paying $740 I would watch eBay and craiglist to piece together an 00-01 cr ignition if you can't find a whole setup below $400.  Also in Phoenix I see complete 00-01 CR 250 bikes sell for $1000 < $1500 so you could buy a bike, pull the ignition, and buy a $75 ESR timing plate.  Then part out the cr 250 and you could probably net out a free ignition if you took the time w/ the CR 250 part out.
86 ATC 330R Duner
88 TRX 350R Duner
06 LTR 535 Duner
Offline fast350r
« Reply #14 on: December 26, 2013, 01:46:18 PM »
X2 Vader , i think we are lucky here in AZ part outs a common and cr250r are for sale everyday by the dozen
Shearer 431 puma
