Author Topic: New seat latch for 2014  (Read 33940 times)
« Reply #45 on: February 07, 2014, 02:14:52 PM »
Quote from: Fire1;25033
Yes , just one set. If its a lot of trouble I'll take one like they are.
I still owe you the calendar badges. I just did not think anyone would want to polish it when I was sanding them. I will make up a couple this weekend and ship it Monday
« Reply #46 on: February 13, 2014, 06:20:44 PM »
 It would be alot of work for anyone to try and polish it complete and with the 100 grit sanded finish. Here's yours Tim. I took the pic before the locators get loctited in. This is just to show a few that wanted to know how they were assembled. The stud is pressed in with 7 tons of pressure to set it in place. Loctite is then applied onto the threads 3/4 of an inch up from the base plate.
« Reply #47 on: February 13, 2014, 07:26:53 PM »
Complete with knobs.
Offline Fire1
« Reply #48 on: February 13, 2014, 07:29:19 PM »
Looks great thank you !
« Reply #49 on: February 13, 2014, 09:59:12 PM »
so what will it take for me to get a setup for my 88
« Reply #50 on: February 14, 2014, 06:55:48 PM »
Offline PNWrider
« Reply #51 on: February 27, 2014, 10:32:32 AM »
Looks good!
You probably thought of this already but would hood pins work well? Seems like it might reduce costs even more.
Something like this...
or this
Just a thought
Pin style thought----Latches are ready to ship.
« Reply #52 on: March 01, 2014, 06:07:12 PM »
Quote from: PNWrider;27066
Thats what the competition is selling for $40 shipped. I am not sold that those hold tight. I prefer to copy the OMF engineering quality. I thought I would match the $40 shipped price for the 86-87 model, but these will hold down tight. The ATC and 88-89 studs are longer and more heavy duty and cost a $1 each more
85-86 ATC that use the tall rubber cushion $42 shipped (Cushions for display only- not included in purchase)
88-89 TRX that use the tall cushion also $42 shipped (Cushions for display only- not included in purchase)
86-87 that use a short cushion $40 shipped (these are what they were all going to be price wise with the short studs) (Cushions for display only- not included in purchase)
86-87 that use tall cushions $42 shipped -for those who have bought tall cushion replacements (Cushions for display only- not included in purchase)
Replacement Carr-Lane knob with clear coat $7
Replacement Carr-Lane knobs set with clear coat $14
These knobs can be purchased from Carr-Lane Current price are $4.70 each see link below
http://www.carrlane.com/catalog/index.cfm/index.cfm?FuseAction=PartCheck&pn=CL-20-HK-4A&Product_ID=114
This post should give Trevor enough info to put them one the website.
« Last Edit: March 01, 2014, 06:17:52 PM by Pumashine »
« Reply #53 on: March 01, 2014, 06:54:22 PM »
So when can i get one tony?
« Reply #54 on: March 01, 2014, 07:05:37 PM »
Quote from: Burns363R;27306
They are ready to ship now! I just learned about the 88-89 needing the taller studs so I wanted to be sure to have everything in stock. I assumed all the TRX had short cushions and only the ATC had tall cushions. The tall cushions that come on the ATC and 88-89 have the little ribs facing up on your frame.
I also have the 86-87 with the tall studs for those of you that have 88-89 replacement cushions. In time all the latches will have the tall studs. But they were twice the price of the short studs.
« Last Edit: March 01, 2014, 07:42:30 PM by Pumashine »
Offline Fire1
« Reply #55 on: March 09, 2014, 03:52:50 PM »
Here's Pumashines ATC seat latch installed
Offline Dirt man
« Reply #56 on: March 09, 2014, 10:34:23 PM »
I would like two for the 88/89 style.
It goes fast over bumps too!
Offline ATVRacing2
« Reply #57 on: May 01, 2014, 07:31:46 PM »
Does the seat latches come with the hardware to mount?? Such as the nuts?
« Reply #58 on: May 01, 2014, 11:01:24 PM »
Quote from: ATVRacing2;32863
 The seat latch is a copy of OEM bolt pattern. All you need is the nuts you take off, put the new latch in its place and put your OEM nuts back on.
Offline ATVRacing2
« Reply #59 on: May 03, 2014, 10:11:57 PM »
Quote from: Pumashine;32881
Ok Thanks, I will be ordering the 1988 Seat latch from you from your site.
