Author Topic: Laeger T-Pin Pro-Trax Spindle Rebuild information - Part Numbers  (Read 25198 times)
Offline Langbolt
Here's an Exploded View of the Laeger T-pin. You MUST remove the Grease Zerk fitting and remove the Spring Pin that secures the two shafts together. Once removed you can unscrew them and dissassemble completely.
Part Numbers are attached for easy replacement.
Enjoy!
Special Thanks to: Croat1,Higgy87TRX425 & c41xracer - for helping me put this together.
Mono Ball Bearing http://www.qualitybearingsonline.com/sbb-10-iko-spherical-plain-bearing-5-8x1-1-16x0-547mm/
Upper combined Needle Bearing http://www.consbrgs.com/page.taf?detail=241_1_2
Lower Needle Bearing http://simplybearings.co.uk/shop/p9704/IKO+TA1725Z+Needle+Roller+Bearing+Open+End+Type+17x24x25mm/product_info.html
Jam Nuts & Tie Rods - 7/16-20 right handed jam nut #94846A520 7/16-20 Thin Hex Nut 1/4" height
http://www.mcmaster.com/#catalog/120/3191/=r3sokl
left hand tie rod end #4444T202
7/16"-20 Left-Hand Male Shank, 7/16" Ball ID, 1-3/8" Long Thread
http://www.mcmaster.com/#4444t202/=r3sozz
right handed tie rod end #4444T201
7/16"-20 RH Male Shank, 7/16" Ball ID, 1-3/8" Long Thread
http://www.mcmaster.com/#4444t201/=r3spd3
7/16-20 left handed jam nut #99612A127  7/16-20 Thin Hex Nut 1/4"height LEFT HAND THREAD
http://www.mcmaster.com/#catalog/120/3191/=r3soeb
O-ring Data & Links
O ring for stem and spindle tie rod blocks #9559K19 -014 1/2"ID(0.489") 5/8"OD(0.629") 1/16"(0.070") tHICK
http://www.mcmaster.com/#9559k19/=r3sq8z
O ring for .875 mono ball #9559K28 -115 11/16"ID(0.674") 7/8"OD(0.880") 3/32"(0.103") Thick
http://www.mcmaster.com/#9559k28/=r3sltn
O ring for .990 mono ball #9559K32 -211 13/16"ID(0.796") 1-1/16"OD(1.074") 1/8"(0.139") Thick
http://www.mcmaster.com/#catalog/120/3510/=r3smgd
:) Found this on FACEBOOK : To purchace full kit
https://www.facebook.com/photo.php?fbid=10205713207930550&set=pcb.10156413551125261&type=3&theater
« Last Edit: December 31, 2017, 11:00:39 PM by Langbolt »
Offline Langbolt
« Reply #1 on: January 06, 2014, 07:53:57 PM »
If you have one like this....It's a LONE STAR...not LAEGER
Offline Langbolt
« Reply #2 on: January 06, 2014, 07:57:03 PM »
Or if it looks like this....It's a GT Thunder - Sure Traxx
Offline Langbolt
« Reply #3 on: January 06, 2014, 08:07:17 PM »
Or if you're capable of machining your OWN Replacement parts....here's some measurments to do so.
Offline Langbolt
« Reply #4 on: January 06, 2014, 08:20:26 PM »
Here's the Spindle
Offline Higgy87trx425
« Reply #5 on: January 06, 2014, 08:21:30 PM »
Beautiful!!!
 Thanks Higgy
Offline brewer_brewer
« Reply #6 on: January 06, 2014, 09:30:44 PM »
I've never seen that gt thunder version
looks like they just modded a 400ex knuckle, cool
« Reply #7 on: January 07, 2014, 12:32:50 PM »
Nicely done Langbolt
« Reply #8 on: January 07, 2014, 08:52:05 PM »
Hey guys,
 So I just pressed out the monoball bearings the sbb-10's. I used a little heat and they came out with ease. I have one of those cheap butane torches, with a pinpoint blue flame and worked great for putting the heat right where I needed it. I heated the bearing itself for about a minute. Then I used 2 sockets, one on each side. So the bearing would have something to fall into when I pressed on it. Worked perfectly, thanks Langbolt!! Hope this helps everyone!
 Thanks Higgy
« Reply #9 on: January 10, 2014, 08:01:21 PM »
Ok guys I suceeded FINALLY!! I used the blind hole bearing puller! Its a "MUST HAVE" for your tool box and saved me alot of money about the best $75 I've spent! I heated up the spindles in the oven to 250 degrees for 20 minutes each!!!
Then I turned the vise facing down after clamping then by the caliper mounts VERY firmly!!! I then used the blindhole bearing puller and slammed the hammer down. Its a little easier slamming it down insted of sideways!!I had to beat the hell outta them, but they came out!! I ended up grinding out one bearing about 3/4 of the way and then using the slam hammer again and it popped out pretty easily after I had relieved some of the pressure off of it! Thanks for the tips guys!! Heres a few pics!
 Thanks Higgy
« Reply #10 on: January 15, 2014, 07:19:40 PM »
So I've been calling around to different bearing distributers, trying to get prices and I kept hearing that there was an IKO located in California and several others through out the US. So I figured why in hell am I dealing with all these middle men that don't even have my bearings in stock anyway??? So I called up IKO directly, LOL! The first thing that they asked me was what business I was calling from, lol! I guess I had needed to be in business. I have someone that works in the industry so I think I have it covered, I guess the next thing I need to do Is see if they're any cheaper if I can cross-reference them?
 Thanks Higgy
« Reply #11 on: January 15, 2014, 07:25:09 PM »
You need to get in touch with either Dan or troy. One of them has all the parts # and the place to buy it all from. This was all covered in one of the other forums. If you can find that link post the info.
« Reply #12 on: January 15, 2014, 10:23:25 PM »
Quote from: Hawaiiysr;22411
Thanks man, I believe I'm getting close, but I need to do some more price checking!!
 Thanks Higgy
Offline Langbolt
« Reply #13 on: March 15, 2014, 11:59:23 AM »
Updated Info - Mar.15-2014 See first Post :)
Offline jannick
Re: Laeger T-Pin Pro-Trax Spindle Rebuild information - Part Numbers
« Reply #14 on: August 18, 2023, 05:34:16 AM »
I see, thanks for sharing the exploded view of the Laeger T-pin. It's very helpful to have a visual representation of the parts and how they fit together. I'm sure this will be a valuable resource for anyone who needs to disassemble or repair a Laeger T-pin. And i also recommend a good source for bearings online:https://en.tradebearings.com
I'm also glad to hear that you were able to get help from Croat1, Higgy87TRX425, and c41xracer in putting this together. It's always great to be able to collaborate with others and share knowledge.
Thanks again for sharing this! It does help even for so many years past.
