Author Topic: Would there be any interest in a high flow CF intake and aluminum box for the 250R?  (Read 15054 times)
Offline troybilt
I actually have a yfz boot on my stock bike now, I don't have the same problems you speak of.  There is a ton of clearance with this setup.  Only issue is I had to make a box cause the OD of the filter end is much larger (which can be a good thing).
Elsinore 496cc Saber
Offline JoePA
hmmm. I'll double check again when I get everyting back together. might be the angle of the Rad valve causing it to hit?
Offline troybilt
What airbox where you trying it with?  This is an airbox I made that is made for the YFZ boot and sits really high in the subframe.  That might be part of the issue.
Offline Dezsled
That Yfz intake looks like a great idea. I need to take another look at it...
I think what fouls it up is the metal extension Doug uses to fit the oem air boot.
\'04 Roll LOBO II TRX250R
\'06 LTR450
\'87 HPR LT500
\'87 LT500
\'85 & \'86 LT250
\'86 & \'87 TRX250R
\'07 & \'09 Husqvarna TE450
\'00 CR125R
Parts & more parts
Offline Mony25
Troy I would deff be intrested in something for a lobo with an air box. Whether it be stainless or what. Willing to wait till you get some of the 450 stuff done however.
01 lobo mx chassis axis shocks c-Leigh ported pro-x 310 (going bigger in future) 38 a/s esr trx 5 pipe hipers an holeshots cr 250 ign flex bars precision stabilizer
86 atc 250r all stock except pipe
Bunch of other 4 stroke atc\'s
Offline troybilt
Sounds good, I'd definitely help you out with something there.
Deff interested.  Tired of these rubber boots on my laeger
Offline Mony25
Troy would there be any way to try out a yfz airboot?
Offline Flyin_250r
I'll be trying out a yfz setup and Troy/Jerry airbox design on my lobo whenever I manage to get it together lol. Already have all the parts, just no time with work and a move coming
Offline troybilt
I sold my yfz setup with my hybrid.
I'd be willing to hand cone a few intakes out of stainless if I had a bike to use or some way to get dimensions...
