Author Topic: Hondzilla  (Read 12850 times)
Offline 1986quadracer
Hondzilla
« on: January 17, 2014, 11:58:28 PM »
The most powerful production atv engine in the finest frame. What more could a guy ask for? It maybe sacrilegious but it is MY bike.  I am the one that's gonna be passing your butt on the trail:) Anyway the project has been going on for about two years now. The engine building was, well, a nightmare but the motor is home and just about ready to fire up. The frame looks to be an old race quad. The frame should have been sent to the scrap yard but everything is fixable. It was repaired using fire and molten metal:) lots of new parts. The wiring and electronics are in the air box. Pretty much the only hold up now is a pipe now. There have been many things in my life that were never accomplished but this is gonna be riden.
Hondzilla
« Reply #1 on: January 18, 2014, 12:55:09 AM »
I can't find anyone with a jig so it looks like I'm doing it. This will be my first pipe. Hopefully one day this site and fellow friends will give me knowledge to build my own from scratch and not copy someone else's. If Jerry does them that would be way sick. Thanks a million!
Offline Higgy87trx425
Hondzilla
« Reply #2 on: January 18, 2014, 01:09:35 AM »
Arlan, at LED was building one of these for a guy a couple years ago, so you might try him for a pipe??
 Thanks Higgy
Hondzilla
« Reply #3 on: January 18, 2014, 04:02:52 AM »
That is my bucket quad. Arlan has a template for the pipe you need. I spoke with him about it around a month ago. Give him a call. He's very easy to work and talk with.
Hondzilla
« Reply #4 on: January 18, 2014, 05:20:27 AM »
very cool build!  the 500cc R is where its at.
Hondzilla
« Reply #5 on: January 18, 2014, 08:50:57 AM »
Sweet! Thanks for all the positive comments. Hopefully Mr. Ness will be up to the task. And hopefully this bike will eat a few Banshee.
Hondzilla
« Reply #6 on: January 18, 2014, 02:43:30 PM »
Had the same trouble witn making a pipe for the pilot cylinder. Got a new pipe and cut it 2" from the exhaust manifold. Then cut a pie shape on the small flange to angle the pipe in the correct direction going around the frame. ESR pipes are real cheap to work with. Its hard for someone else to build you a pipe that will fit due to variance on where it is mounted. You may end up welding in a spacer or cutting it shorter in the straight section coming right out the exhaust manifold.
Hondzilla
« Reply #7 on: January 18, 2014, 02:56:13 PM »
Quote from: 1986quadracer;22592
The only way to build a custom pipe on a hybrid is to have the bike in the pipe builders shop.  I have never seen two identical hybrids and the parts seem to never interchange.
Hondzilla
« Reply #8 on: January 18, 2014, 03:20:43 PM »
Good deal! Thanks Jerry;) You just lit a fire up under my butt. I owe you one big time!
Offline Maxxh2o
Hondzilla
« Reply #9 on: January 18, 2014, 04:39:29 PM »
Quote from: Higgy87trx425;22594
 Thanks Higgy
That was most likely my bike you saw there.....has had its taste of banshees over the last few years :)
Hondzilla
« Reply #10 on: January 19, 2014, 01:54:33 AM »
Arlan can build you the pipe and not weld certain sections ie, header, stinger, mounts. That way you can position the pipe to where you need it.
Hondzilla
« Reply #11 on: January 21, 2014, 10:04:09 AM »
Aaen performance also build a Honda frame hybrid pipe
Offline JoePA
Hondzilla
« Reply #12 on: January 21, 2014, 12:43:10 PM »
Direct form AAEN website.....
"The newer high volume pipe (PAT 1002) is also available for those who fit the Quadzilla engine into the 250 Four Trax Honda chassis. The Aluminum Silencer is also available for this version (PAT 1003), As well as the Spark Arrestor version (PAT 1003-SA)."
Hondzilla
« Reply #13 on: January 21, 2014, 02:34:51 PM »
Nice. Doesn't look to costly also
Hondzilla
« Reply #14 on: January 21, 2014, 03:03:01 PM »
Man thanks a TONS! You guys are the diggity:)
