Author Topic: Leak down test  (Read 10430 times)
Offline 4WHLr
Leak down test
« Reply #15 on: January 22, 2014, 12:20:53 AM »
Thats what i'm thinkin
1986 TRX275R PC2000
Leak down test
« Reply #16 on: January 22, 2014, 08:12:47 AM »
Quote from: hub97119;23012
I looked at the tech sheet...good explanation, but I'm thinking you may have found the weak link in my theory more than anything. "You arent introducing any more air volume to have anymore pressure in there." So simple  pressure in the cyl. without additional volume won't give a true leak test ? correct ?
Yep, now you got it. It's fun to think through stuff like this though, and finally understand why.
Offline wilkin250r
Leak down test
« Reply #17 on: January 22, 2014, 12:57:13 PM »
When you turn the crankshaft and move the piston (using the kickstarter), you are moving air from the crankcase into the cylinder. So while cylinder pressures go up, crankcase pressure will go DOWN if the intake is sealed off.  It's a closed system, you're just moving it from one place to another.  The only way to pressurize a closed system is to add pressure from an outside source.
It's like going to the ATM. Pulling $100 out of your bank account and putting it in your wallet doesn't make you "richer", you don't have more money overall. You have the exact same amount of total money, it's just in your wallet instead of your bank account.  The only way to get "richer" is to add more money from an outside source like a paycheck.
Leak down test
« Reply #18 on: January 22, 2014, 01:25:12 PM »
^^ :encouragement: ^^ When you you put it that way, even I can understand! Great example. :applouse:
