Author Topic: Swing arm bolt stuck & looking for suggestions  (Read 9582 times)
Offline fx4pitrone
« Reply #15 on: January 26, 2014, 10:57:12 PM »
What is the best grease to put on that bolt?  I've always just used Bel-ray grease, or Lucas red (w/ the anti-seize) but curious if there are better options as i haven't really thought about it....
Offline ACHillshooter
« Reply #16 on: January 26, 2014, 11:46:08 PM »
This happened to me last week. Bolt would spin freely but would not budge. I soaked it for days with penetratong oil and it still wouldnt move. Turns out I was NEVER going to get it with a hammer. I put the bike up on a steel table, tacked two tubesteel post to the table, one on each side. Then put a piece of steel pipe over the bolt head between the frame and tubesteel post. I then put a porta power between the bolt and other tubesteel post. It was so stuck the entire bike moved before the bolt budged so we had to tack a large piece of angle iron to the table and bolted it to the peg hole. We really cranked up the porta power and finally it jumped about 1/2" with a loud crack. Reset the setup and got it to move again about 1/2". Used a piece of round bar to get it about halfway through and then was able to hammer it out. It took so much force that the 1/2" thick steel table flexed almost an inch on either side before the bolt moved! So yea a hammer would NEVER have worked. But I saved the bolt.
