Author Topic: ct 330 porting  (Read 6189 times)
ct 330 porting
« on: February 05, 2014, 10:35:18 PM »
I just got a 88 250r with a ct330 motor. Is there a way to tell from the outside if they did anything special on the porting. Like markings they might of done. Thanks in advance
ct 330 porting
« Reply #1 on: February 06, 2014, 10:27:01 AM »
Most cylinders have engravings under the intake/reed valve. Other than that there wouldn't me a way to tell other than taking the cylinder off and measuring stuff.
ct 330 porting
« Reply #2 on: February 06, 2014, 10:52:54 AM »
ya the only thing I can see under there is previous owners name scribes there
ct 330 porting
« Reply #3 on: February 06, 2014, 11:17:44 AM »
Quote from: hickwheeler;24903
This is a long shot but may be worth the effort.  Call up CT Racing and ask them if they have any record of that cylinder (and how it was build) based on the previous owners name.
ct 330 porting
« Reply #4 on: February 06, 2014, 11:52:02 AM »
I already tried that. they didn't have records of the build. just showed when it was sent back for new piston and bore.
ct 330 porting
« Reply #5 on: February 06, 2014, 12:02:19 PM »
is the cylinder off the bike right now? You can measure the port heights and some of the guys on here can tell you what it's ported for. CT is usually known for "cookie cutter" port jobs, another builder would likely be able to improve on it
ct 330 porting
« Reply #6 on: February 06, 2014, 02:38:45 PM »
no still on the bike. probably going to pull the head off in the next couple off days. just to see how things are looking inside.
ct 330 porting
« Reply #7 on: February 06, 2014, 06:44:56 PM »
I'm not real worried about if it is ported or not. wanting to pull head off to see condition of it to somewhat know were I'm at with it.
ct 330 porting
« Reply #8 on: February 07, 2014, 03:26:48 PM »
If it is CT porting, it will have a good amount of texture to all of the walls, not smooth & go on up into the reed chamber as well.
It will look as if some type of small round carbide was used, with points on it instead of sharp blades & maybe rotated backwards to just scar the surface instead of cutting.
You should be able to tell, that a good amount of metal has been removed to change angle flows & then the round carbide used to finish the surface off.
ct 330 porting
« Reply #9 on: February 09, 2014, 11:04:44 PM »
The cylinder doesn't seem to be ported. I took of the carb and reed cage and had a look. Was wondering if you guys could tell me what style reed cage this is. I'm thinking cr250. it had this and the intake boot swapped out. I have the stock setup also. Sorry for bothering you guys. Just get tired of trying to get a hold of original owner and builder.
[/URL][/img]
[/URL][/img]
ct 330 porting
« Reply #10 on: February 09, 2014, 11:35:42 PM »
did some looking on ebay and it does seem to be a reed cage from around 99 to 01 cr250. but if any one knows for sure please let me know.
Online Jerry Hall
ct 330 porting
« Reply #11 on: February 09, 2014, 11:39:41 PM »
Quote from: hickwheeler;25227
[/URL][/img]
[/URL][/img]
The reed looks like a OEM Honda cage with Boysen reed petals
