Author Topic: Alternative Rear brake Caliper??  (Read 69605 times)
Offline Langbolt
Re: Alternative Rear brake Caliper??
« Reply #90 on: December 29, 2020, 05:42:44 PM »
Jeremy & I never got it off the ground....I ended up making a new bracket that made the Front Caliper an easy bolt on!
Offline Pj Uptmor
« Reply #91 on: December 29, 2020, 06:04:40 PM »
2008 Ltr 450r rear brake piston works in the trx 250r caliper
Offline Langbolt
« Reply #92 on: December 31, 2020, 09:45:34 AM »
Are you sure ?
It looks like the Rear Caliper on the 2008 Ltr 450r is a Single Piston caliper.
« Reply #93 on: December 31, 2020, 02:14:10 PM »
Are you sure ?
i think he is talking about just the piston. not the complete caliper
Offline Langbolt
« Reply #94 on: January 02, 2021, 02:40:06 PM »
[/quote]
Correct.....Single piston Calipers usually use LARGE pistons.....as compared to the TRX250R small pistons.
The YFZ450R pistons are the same Diameter....just a bit longer.....Surely there has to be an exact fit out there SOMEWHERE!!!!!
« Reply #95 on: January 02, 2021, 04:12:15 PM »
K&L doesn't have an offering? They used to have rebuild kits. Haven't looked in some time
« Reply #96 on: January 03, 2021, 10:52:58 AM »
The last time I looked the rear caliper pistons were no longer available from K&L.
