Author Topic: Anyone make fender brackets for Maiers  (Read 11468 times)
Offline bnau267
« on: February 16, 2014, 12:48:20 AM »
Let's see those home made brackets for the front fenders.  I'm not paying $50 or a set of OEM fender mounts.  Has anyone made new brackets that run from the frame to the lower front fender mounts?
Offline bnau267
« Reply #1 on: February 16, 2014, 12:58:15 AM »
I think I'm gonna buy me some welding, bending, and cutting equipment....lol.
« Reply #2 on: February 16, 2014, 10:14:21 AM »
Just a nut welded to some all thread and a coated clamp with nuts for round frame tube. I've read that welding wire can be bent for a stock frame.
« Reply #3 on: February 16, 2014, 10:25:58 AM »
This requires a welder. Mock everything up for a good fit tack it then remove to complete welding. No more limp fenders.
Offline bnau267
« Reply #4 on: February 16, 2014, 11:20:41 AM »
Quote from: rk88r;25735
I'm buying a welder....lol.  Nice work.  So it appears we are on our own....no one is actually making this stuff?
« Reply #5 on: February 16, 2014, 11:34:11 AM »
Someone should, I doubt I could make money at it.  Those maier two piece fronts need it though.
Offline fx4pitrone
« Reply #6 on: February 18, 2014, 10:03:12 PM »
If anybody can step up and make a set, I'd be in for a set of front lowers as well as I need a set soon.....?
« Reply #7 on: February 18, 2014, 10:18:27 PM »
Quote from: rk88r;25744
If you want any parts made to weld up these kits just let me know. I would like to make the parts so these fenders work as good as OEM.
Offline bnau267
« Reply #8 on: February 18, 2014, 10:22:34 PM »
Quote from: Pumashine;26019
If you want any parts made tp weld up these kits just let me know. I would like to make the parts so these fenders work as good as OEM.
I like the rk88r design.  I can't weld...not yet at least!
« Reply #9 on: February 18, 2014, 11:10:03 PM »
If you can use  color crayons then you can mig weld.
« Reply #10 on: February 19, 2014, 10:47:36 PM »
It's all really basic stuff. I copied maiers "z" brackets and added a 1/2" because I think theirs are too short at least with my 3.6 ims tank. The cross is just 1/2" tubing with tabs on the end. I did slot the tube a little at the z's for a little more weldable surface. The most time consuming part of it was getting the perfect width for the maier hood to lay nice. I'm happy with the performance of mine they weren't meant to be "show grade" though. Anyway Puma stamping out the "z's" with the little bit of twist they have is probably has most need for mass production. If I took the time to make a jig they could be made very quickly.
« Reply #11 on: February 19, 2014, 11:09:18 PM »
Quote from: rk88r;26159
I think I added over 1" to Jons front brackets that hold the hood up. The supplied hardware in my eyes are junk. All fender makers use cheap mounts that are completely insufficient. I am willing to help make mounting hardware for whatever fenders we will be able to buy in the future. Maier, Fullbore, and Laker just don't give a rats azz what is used to hold them up. I personally talked to Fullbore and Laker. They think the mounting hardware they supply is awesome.
« Reply #12 on: February 19, 2014, 11:17:39 PM »
Right now I'm swamped with work. I spent a lot of time mocking this set up, so if I made a jig of them they could be cranked out quite reasonably.
Offline Wes350x
« Reply #13 on: February 19, 2014, 11:33:10 PM »
I used a steel rod from ace hardware and just bent some circles on each end to put a bolt through and bent the proper angles needed. Only cost a few bucks and I sprayed them black after and they look great. I can get pics tomorrow.
1988 250R
Offline bnau267
« Reply #14 on: February 19, 2014, 11:51:54 PM »
Quote from: Wes350x;26176
That would be great.  Looking for ideas.  Agree with Puma that the setup from Maier leaves a lot to be desired.  Seems to me there would be some level of demand for an improved fender mount/brace setup for Maiers.  Maybe even something for the rears.
