Author Topic: Anyone make fender brackets for Maiers  (Read 11466 times)
« Reply #15 on: February 20, 2014, 12:21:32 AM »
I like the way quadzilla rear fender supports are.
Offline Wes350x
« Reply #16 on: February 20, 2014, 07:35:56 PM »
Here's thr rod I bent and painted.
1988 250R
Offline bnau267
« Reply #17 on: February 21, 2014, 09:04:53 AM »
OK - we are in business.
Lowers = Wes350x
Uppers = rk88r
Design, Development, and Testing complete....now we need a Manufacturer/Distributor to set price and start filling orders.
Offline Wes350x
« Reply #18 on: February 21, 2014, 09:44:25 AM »
Quote from: bnau267;26340
Lowers = Wes350x
Uppers = rk88r
The ones I have on my fronts I believe anyone can make with a vise and hammer.  Cut to length, put in vise and bent the curve by hitting with a hammer using a bolt inside to make the curve. Prob would be super easy to heat it up good first. Then sanded and sprayed black. The rod was super cheap $.
1988 250R
« Reply #19 on: February 21, 2014, 11:31:23 AM »
Quote from: Wes350x;26297
Did you use the torch for that?  The rod looks to be about 3/16 in diameter?
Offline Wes350x
« Reply #20 on: February 21, 2014, 01:43:17 PM »
Quote from: Pumashine;26357
I believe I did use some heat from a propane torch to make it a little easier. I also think you are right, 3/16" stick.
1988 250R
« Reply #21 on: February 21, 2014, 07:28:12 PM »
I would be very interested in this if I can't find Fullbores.
I think this is something that would sell very well.
Offline mx250r91
« Reply #22 on: February 22, 2014, 10:32:19 AM »
I just bent some spring steel rod to attach the front fenders to the frame. My frame (aftermarket) doesn't even have provisions for the stock brackets so I attached them with stainless hose clamps. Ghetto but works flawlessly!
Offline nico
« Reply #23 on: February 24, 2014, 03:49:23 PM »
I made some years ago, using some 1/8" by 1" aluminum strap from Tractor Supply... Worked perfectly to drill bolt holes in each end, then bend to fit.  When I was done, I just sanded and polished them.  I have since replaced them with chrome stockers, just because I got some as part of a package deal parts swap.
Offline TRXforever
« Reply #24 on: May 11, 2014, 09:29:03 PM »
Might you have, or can you get, another set of these??
Offline Wes350x
« Reply #25 on: May 11, 2014, 09:50:54 PM »
Quote from: TRXforever;33702
I don't, but they were pretty easy to make.
1988 250R
