Author Topic: Drill Bits or Maybe Advice  (Read 4695 times)
Offline trx88
« Reply #15 on: February 17, 2014, 12:08:15 PM »
slow with pressure, start small, and revert from small to large back and forth
really helps to start with a small bit and go to progressively bigger ones
back and forth
ALWAYS use oil or wd40 when your drilling metal and drill slow
what my shop teacher taught me and works well
also helps to learn to sharpen them on a grinder
you can get more out of your old dull bits and not be afraid to dull them
and quench often when sharpening
Offline bnau267
« Reply #16 on: February 18, 2014, 08:34:03 PM »
Got to thinking.  The company I work for has a giant fabrication shop.  These shavings caught my eye!
Everything they do is super sized (Underground Mining Industry).
Offline wilkin250r
« Reply #17 on: February 19, 2014, 01:32:51 AM »
I'm with Neil on this one.  Left-handed drill bits.  I can't tell you how often I've gotten only a few thousands deep into a bolt and have it back itself out just because the drill bit is biting into it.  If it's drilling bolts, I would rather have a cheap set of left-handed bits than a really expensive set of right-handed bits.
What I most often do take a dremel with small, round carbide bit (often an engraving bit) and put a starting hole into the bolt, similar to a centerpunch, to keep the bit from wandering.
Offline bnau267
« Reply #18 on: February 19, 2014, 10:29:41 PM »
Quote from: wilkin250r;26041
The dremel technique works perfect.  I'm gonna get me a set of left hand bits.
Offline 312R1
« Reply #19 on: February 20, 2014, 12:07:44 PM »
Bob, remind me when you come up this weekend to show you what I use to get broken bolts out. Best gift I have ever got from the wife as far as tools go.
